New! Dark mode!
(Topic ID: 252863)
Bram stokers Dracula pinball question
By Tycho
1 year ago
  • 11 posts
  • 5 Pinsiders participating
  • Latest reply 1 year ago by Tycho
#1 1 year ago
Hey guys. I’m new to owning a pinball machine but had a question hopefully you guys could answer for me. There are two pinballs in the back right side of the Playfield. I think the first time I flipped my Playfield up one of the pinballs dislodged and flew backwards and got lodged in the back right corner. Is it normal to have two pinballs lodged in this corner? If not any suggestions as to how to get them out? Thank you in advance.
889D9D5C-4999-4B27-8547-F2A15C115A88 (resized).jpegE06A8619-43D0-45F9-9AC2-84E526B51F76 (resized).jpeg
#2 1 year ago
Try a magnetic pickup tool to fish them out. Your machine uses 4 balls.
#3 1 year ago
And always a good idea to take the balls out before raising the playfield
#4 1 year ago
Quoted from dr_nybble:
That’s a great idea thanks!
#5 1 year ago
Yes, it’s common for balls to end up back there. You don’t want them there, but they can end up there.
#6 1 year ago
Just bought this off amazon hopefully i can fish them out with this!
#7 1 year ago
Yup, every good pinhead needs one of those! Handy in numerous circumstances, including removing balls before lifting playfield.
Newbie tip: another trick for lifting the playfield without removing balls: cut a small piece of foam to jam in the shooter lane to keep the balls in place. Easy to forget to remove after work is done though, ha.
#8 1 year ago
Quoted from HighVoltage:
#9 1 year ago
Does having the pinballs stuck in the back corner affect gameplay at all?
#10 1 year ago
Balls getting in areas where they aren't supposed to be can affect gameplay or even cause unexpected havoc. In this instance it looks harmless, but there are bulbs and an opto back there. I wouldn't leave a ball there, one unlucky bounce when lifting the playfield and it could damage something. In other cases, a stuck ball might short-circuit electronics, blow a fuse, break opto beams, etc. So they could affect game play or do damage.
I just took a look at my BSD, and dropped a ball back there. I found it straight forward to get out by lifting the playfield 45-degrees and holding with my left hand while I use my right hand to direct the magnetic pick-up wand in through the opening at the side under the ramp.
#11 1 year ago
Thank you for the detailed explanation I appreciate it!
Arcade Upkeep
$ 128.00
3,998
Bellmore, NY
