(Topic ID: 29878)
Bram Stokers Dracula Club....Welcome to the Carpathians
By shacklersrevenge
7 years ago
  • 7,072 posts
  • 582 Pinsiders participating
  • Latest reply 7 hours ago by Spacemanratso09
  • Topic is favorited by 225 Pinsiders
There have been 2,164 images uploaded to this topic. (View topic image gallery).
31 key posts have been marked in this topic, showing the first 20 (Show topic index)
There are 7072 posts in this topic. You are on page 41 of 142.
#2002 5 years ago
The parts list, you know I looked at that before posting this question and said "Meh, this won't help". Sigh, its been a long day.
Could you guys tell me which goes where? Long in the back short in the front? I know that is not in the manual, I checked for that.
#2003 5 years ago
Quoted from Glarrownage:
Long ones go in the back and short in the front.
#2004 5 years ago
Quoted from Bryan_Kelly:
Thanks again Bryan! You have done so much work on my machine I feel like I should be paying you for it.
So, obviously the shorter pivot nuts were on the back, would that be the cause of the slide assembly slipping off? Just trying to understand how this happened:
#2005 5 years ago
I would think so, yes. The entire playfield pivots on the back and if they're not long enough, you could have trouble.
I've seen a number of games with shorter ones in the front and if you look under the playfield, that's usually because there are parts mounted close to the slide assemblies and longer ones would interfere.
IMG_20140904_095906_010.jpg 104 KB
#2006 5 years ago
Quoted from bigd1979:
Ok I need a few pieces on my bsd and figured id ask here first I need the plastic thats above the 3 bank targets below the pops and I need the plastic shroud behind the grave marker that covers the light houseing and wires . Pm me if you have extras thax
Anyone ? I found everything but the plastic behind the grave marker .someone with a nice one wanna take some pics of it off ? Maybe I can make one im not worried about thee sticker on it . Im sure oalot people could use this piece
#2007 5 years ago
Many people who need it probably picked up Bryan Kelly's set.
#2008 5 years ago
His set don't come with this part actually or I would just order a whole set .
#2009 5 years ago
Hey Big, my BSD is all torn down right now but I'm sure I can get a pic of that plastic for you. I'm not quite sure which one you are looking for though.
#2010 5 years ago
Its the plastic shroud behind the gravestone with the lights in it.it covers the wires and light sockets
#2011 5 years ago
Sorry, this would be way easier if I had my table together. I'm still not sure exactly what your looking for. Could you point out the general area in this pic?
#2012 5 years ago
Behind the coffin
#2013 5 years ago
Behind the coffin
Somewhere around here?
#2014 5 years ago
Yes im missing that and its impossible to find
#2015 5 years ago
I'm sorry, I completely misread your post. If Glarrownage can't get you pics, I'll pull mine out for you.
#2016 5 years ago
If you need more pics or if you know someone who can cast a mold they can use mine as a template.
#2017 5 years ago
Thax guys there's more to it than I originally thought
#2018 5 years ago
Any word on some replacement ramps for this brutal game?
#2019 5 years ago
Only that they're in the works...
#2020 5 years ago
Hey everybody, working out some possible sound issues with my BSD. When I run a sound/music test I only have 11 clips that play. Some are music and some are speech. I know there are WAY more than 11 sound clips in the game. Is this correct amount for the test? Can someone run a sound/music test and see how many play on their machine? Thanks as always!!
#2021 5 years ago
Hey guys, I noticed when looking at other peoples pictures, a metal ball guide attached to the left side of the left ramp on my table is different than others. Most other tables have a triangular shaped ball guide (top picture). I seem to have a straight ball guide (bottom picture. Does anyone else have a straight guide on the left side of this ramp or is it just me?
#2022 5 years ago
I suspect just you.
Quoted from MikeTangoIndia:
I'll try to remember to do this tonight and report back.
#2023 5 years ago
image-8.jpg 200 KB
IMG_20140824_162931_724.jpg 155 KB
I have two BSD's here and one has the guide with the finger and the other has the straight guide. The finger is there to prevent ball traps. On the one with the straight guide, there should be a couple of plastic posts mounted to the ramp to do the same thing as the finger.
#2024 5 years ago
#2025 5 years ago
Is this a wood vs metal side rail thing?
#2026 5 years ago
Just the eleven
#2027 5 years ago
Quoted from aobrien5:
Lol. Not really sure. Looks like it was a change made midway through production.
#2028 5 years ago
Thanks Bryan, good to know its not just me. I'm going to owe you at least a case of beer when this BSD is all said and done.
I have the triangular one.
Thanks for the pic! It seems like everyone has the triangles.
Funny you mention it. I have the metal ones and the next problem I have to figure out is how to fix the damage on the side rail. I'm thinking maybe black powder coat on the whole thing?
#2030 5 years ago
there goes the wood/metal rail thing coinciding with the straight/triangle guard. I have metal rails and a triangle guard.
I have the same scratch in my metal rail, so I'll be interested to see how you fix it.
#2031 5 years ago
If anyone need pics of any assemblies below the playfield (or anything else for that matter) let me know. Mine is totally torn apart now but most of the assemblies are together.
#2032 5 years ago
Hi all,
Between balls there is a score popping up. right now it is 168.000.000, other times it is
199.000.000. What does that mean? is it the replay score?
Axl
#2033 5 years ago
Quoted from Axl:
Hi all,
Axl
Based on your description, I would say yes.
#2034 5 years ago
hi glarrownage, can you post some pics of the diverter and up/down ramp assemblies. thanks joe
#2035 5 years ago
Thirded. I bet this problem is close to universal on metal rail BSDs. I'm admittedly clueless about restoring metal like this, but it seems like there'd be a product you could brush in there and then dab lightly so it would dry to a similar enough texture. Maybe a layer of something else to seal it up. Of course matching the color and texturing would likely be very difficult.
Would it look better than the scratch of outlaner shame, though? Probably.
#2036 5 years ago
Quoted from Axl:
Hi all,
Axl
This will be before you launch the last ball ... indicating what you have to do to earn that replay
It's adjustable in the settings. Yours will be dynamic, if you regularly score big the "to reach"-score will increase, and vise versa
#2037 5 years ago
Quoted from joe2012:
Hey Joe, no problem. Let me sort through my existing pics and find the proper assemblies and I'll post them for you.
#2038 5 years ago
Joe, if this isn't what you were looking for or you wanted a different angle just let me know!
Diverter:
Entry:
#2039 5 years ago
thanks those pics are great.joe
#2040 5 years ago
So, here is video documentation of the left gate problem I was having. Two videos - first is an explanation of the problem. Second is the fix applied and demonstration of the mist ball behaving.
Enjoy!
Video 1 - Problem:
Video 2 - Fix and Demonstration:
Recorded with a GoPro Hero 3+ Black edition.
#2041 5 years ago
Quoted from NPO:
Enjoy!
Video 1 - Problem: » YouTube video
Video 2 - Fix and Demonstration: » YouTube video
Love the GoPro video, its a really interesting way to show a problem/repair. Thanks for sharing!
#2042 5 years ago
You're absolutely welcome . I am going to try to this for all my fixes and repairs from now on. I feel it's very helpful for anyone interested.
You can only read so much, understand what is being talked about, and follow along with interest. It's a whole different thing to visually see what's happening. Definitely glad to contribute to the community in this way .
#2043 5 years ago
Quoted from NPO:
Agreed, very cool! Thank you!
#2044 5 years ago
No, thank YOU for your thread on your BSD. Wow, you're doing some amazing stuff! I may have to ask you some questions on what you're doing - very cool stuff!!!
#2045 5 years ago
So, I decided to go ahead and install the mystery hole cliffy for BSD. And wow, to get to that one area of the game, well, might as well just do a minor shop job while you're in there!
This is the first pin I have ever gone this far with. I have heard BSD is quite a bear to do. So far, lots of photos, couple videos, and some swear words and MacGyverisms - but we are on our way! Some photos of our progress.
10671288_10152550447293710_302225646273719919_n.jpg10357806_10152550447503710_8647514237023507556_n.jpg10433778_10152550447923710_998574795307611429_n.jpg10704079_10152550447653710_935404618306506177_n.jpg1453493_10152550451348710_5125721223996268881_n.jpg10640989_10152550451198710_7511470628475692266_n.jpg10672354_10152550451273710_2492116595309493015_n.jpg10369689_10152550471753710_8341729219542703324_n.jpg10348541_10152550471533710_1221828265966152575_n.jpg10301201_10152550471623710_5718001211045440045_n.jpg
#2046 5 years ago
Quoted from NPO:
I really appreciate that! But, I can tell you I would be no where without the talent pool here on Pinside. Guys like Bryan Kelly and PinballMikeD are huge assets to the hobby the way they share knowledge. Without them passing down their knowledge many more pins would certainly go to waste. I'm just here to learn and subsequently pay it forward as best I can. Feel free to ask any questions you want!
#2047 5 years ago
Quoted from NPO:
Gotta be careful shortening the spring. If it's too short, the gate won't sit low enough at rest and will get in the way of the ball too much. Since it's not available anymore, you want to protect it (and of course you don't want it interfering with the ball when it shouldn't be).
#2048 5 years ago
Finally able to join this club. Wish I had joined years ago when the game was going for under $1000!
Got mine back from York (thanks again Carl!) and now the work begins. The cat is already looking forward to sleeping on the backbox.
#2049 5 years ago
Quoted from neurokinetik:
Was this the one at the show that was priced at $2k? It looked pretty nice! Played well, seemed to work 100% from what I could tell. Great deal!
#2050 5 years ago
Yea I saw 3 or 4 bsd there not sure which you got tho, but all them but the one in the flea market were pretty decent for the price
Trade
Machine - For Trade
Oceanside, CA
