New! Dark mode!
(Topic ID: 29878)
Bram Stokers Dracula Club....Welcome to the Carpathians
By shacklersrevenge
7 years ago
  • 7,513 posts
  • 622 Pinsiders participating
  • Latest reply 1 day ago by mbt
  • Topic is favorited by 243 Pinsiders
There have been 2,341 images uploaded to this topic. (View topic image gallery).
31 key posts have been marked in this topic, showing the first 10 items. (Show topic index)
There are 7513 posts in this topic. You are on page 29 of 151.
#1401 6 years ago
Didn't have to take much apart to Chang my GIs to LEDs.But some are a bit tricky would help if you have long fingers.
#1402 6 years ago
hi blackbeard,do the g.i. from under the playfield. do the flashers too. see ya at pinfest. joe
#1403 6 years ago
So all GI can be swapped from under the pf?
#1404 6 years ago
no there is 3 555's under the left ramp.but you might be able to get at them if you loosen the ramp. joe
#1405 6 years ago
Thanks for the tip joe2012 I will look into that!
What kind of LED flashers is everyone using behind Love Never Dies?
As mentioned I have the Cointaker strip there which looks great, but if I have to remove one mod that'd be it since that's technically only supposed to light when you get a quickly drained ball. So basically what's the brightest LED flasher that would fit there?
#1406 6 years ago
Quoted from n0s4atu:
How about putting a dedicated 12v supply into your service-outlet
Could be it works all fine after that
#1407 6 years ago
Quoted from Thor-NL:
Ok, being almost completely clueless where is the service outlet and how is that done?
#1408 6 years ago
the service outlet is always on.it's in the silver box on the bottom of the cabinet.to the right of the coin box. joe
#1409 6 years ago
Quoted from joe2012:
^^ where he says it is
Plug in your powercord
#1410 6 years ago
Hmm, that empty cut out looks suspiciously like it could have once held an outlet. I know my game was a reimport from Europe, could that be why it's gone?
#1411 6 years ago
Haha, yup. Looks very familiar. Just like my reimport. Not too tough to install a new one. There was a thread about it not long ago.
#1412 6 years ago
service outlet.jpg 170 KB
That's exactly why it's gone. No sense in putting in a 120 volt outlet in a game going overseas. Normally there would be a rubber plug in the hole.
#1413 6 years ago
Jeez, I didn't even get the rubber plug. lol I'm glad to know I just wasn't not seeing it.
I need to learn a bit more about electronics. I assumed that since the DKPinball FS-8 had 8 plugs in it and I had only 3 mods to plug into it, surely it must be able to handle that without a fuse blowing. I suppose it's rather like saying "I can't be out of money, I still have checks left."
Time to hunt down the thread aobrien5 mentioned and see what I can do. Worst case scenario I'll simply convert the topper to a regular plug, since I have an outlet right up there from where the TV was before I had BSD.
I'm sure glad you guys are here for me to ask silly questions to, I'd be lost without this thread and Pinside. So thanks fellas.
#1414 6 years ago
Here you go.http://pinside.com/pinball/forum/topic/what-are-the-differences-with-a-reimport
#1415 6 years ago
Quoted from aobrien5:
Thanks, this helps a ton and doesn't look overly difficult.
Question to anyone who might know, since the 12V fuse is what kept blowing and I actually had things plugged in two different places, one on the just inside the coin door on the left panel at the bottom and then using the DKPinball tap up at J117 in the back box. If I add in plug should it keep things from blowing if I plug one in there? While I can do things like route coax behind walls, install outlets behind tvs I've mounted on walls, etc. The actual knowledge of what is too much power in a pinball is way beyond me.
#1416 6 years ago
That it , it done, if anybody want one let me know(d-r-a-c-u-l-a insert) , it $40 each+ SHIP
#1417 6 years ago
I am just creating problems as I LED this game. the ball is not recognized after going into mystery /mist hole. It looks like the kicker is not working. I guess to start look up the kicker number and try it in the switch test mode? I had the bottom ramp off replacing LED's and it worked fine for a time...
#1418 6 years ago
Is the ramp/subway resting underneath the metal plate that the coil is on? if so, that might be preventing the ball from rolling onto the vertical uplift kicker (VUK) and being read by the optos. If it is under the plate it acts kind of like a step and if the ball does not have enough speed it can not roll into the circular hole on the plate. Thats what happened to me.
#1419 6 years ago
If you go into a solenoid test you can see if the coil is working. If it is, go into a single switch test for that part of the game. The optos that act a switch should be reading closed. If the ball is on the VUK the switch should be reading as open. If the coil and optos are ok, then it is a chance that the ball is getting hung up.
#1420 6 years ago
Quoted from mcclad:
THANK YOU
I think this is exactly the issue. When I return to where the game is I will look but when I reinstalled the subway I remember looking at that fitment and wondering if it was right. I had a difficult time fitting the subway back after replacing LED's. Is it supposed to be flush with the kicker? This is the same area where the GI is all of a sudden not working also but I don't see were I disconnected a wire.
#1421 6 years ago
What color/type LED look good for the 3 under the ramp?
#1422 6 years ago
Quoted from Tyson1868:
I have frosted purple CoinTakers. Doesn't wash out the decal print but acentuates it, imho
#1423 6 years ago
That's a good idea. I have purple in that area too, but the purple flex did wash it out, so I put yellow flex in there.
#1424 6 years ago
looking forward to this club, my BSD should arrive tomorrow. can't wait.
#1425 6 years ago
Quoted from Troutfarm:
Its a great machine to play, need to get the left ramp, LOTS!!
#1426 6 years ago
THANK YOU
If you want I can try to post a picture tomorrow of the way that my subway is installed. Once I changed the way that I had originally installed it, I had no problems.
#1427 6 years ago
Quoted from mcclad:
I would really appreciate the photo. I have not had a chance to look at the game as it is not at home right now. I am storing it at my local arcade where it is easier to install LED's and fix certain items. I am very confident this solution is the answer.
Does anything need to come off before I remove the left ramp?
#1428 6 years ago
I have the purple just before that area under the left middle targets. I will give it a try.
#1429 6 years ago
I think the left wireform. You just have to very carefully lift the ramp entrance. Its difficult to reach the back bulb. Hopefully you have long fingers.
#1430 6 years ago
delivery of my clearcoated BSD is not till tomorrow now.
#1431 6 years ago
It will be worth the wait. That game can be brutal. Great for a home collection. Good luck with it.
#1432 6 years ago
yeah, I was warned about this one in particular being extra brutal with the CC playfield. that is what keeps a home game interesting.
#1433 6 years ago
Which LEDS are you guys using in the GI on the playfield? Ultrabrights? Cool?
#1434 6 years ago
I found that super bands really help the brutality of this game. its still brutal, but i found my score doubling since i put them on.
#1435 6 years ago
Quoted from Blackbeard:
Cointaker retro. Cool on the lower, red in upper right, purple in upper left.
Quoted from CptAwesomest:
I have to agree here. Same experience.
#1436 6 years ago
Quoted from mcclad:
Here is how I believe the subway should rest on top of the plate for the up kicker. I had it underneath it and the ball would not move into position to be shot up onto the playfield. Since I changed it I have not had any problems.034.JPG
#1437 6 years ago
Can I join
#1438 6 years ago
Welcome Kiwi!
#1439 6 years ago
Quoted from Kiwipinhead:
Can I join
2014-04-29 10.25.45.jpg 334 KB
Only if you plan on staying.......FOREVER!!!
#1440 6 years ago
Christchurch - You better bolt wind back the tilt switch , WELCOME
#1441 6 years ago
Quoted from mcclad:
034.JPG 39 KB
That was exactly the issue. THANK YOU!
I should have been paying attention. If I could only find the issue with my GI lights. I will keep at it.
#1442 6 years ago
Joining the club this saturday.
QUestion for you guys: what's the best way to protect the area where the ball drops off the shooter lane? I was thinking a piece of that removable mylar stuff.
Anyone have any thoughts to protect this area from wear?
#1443 6 years ago
I'm new to the hobby, so I don't know if mylar is the best solution, but it's what I plan on using, once I touch that area up, because while the rest of my game looks pretty nice, that area has taken a beating to the point of paint loss. So, while I can't be sure what's best, I highly recommend putting something there if you plan on playing the heck out of it.
#1444 6 years ago
I wouldn't put actual real mylar down. Someone makes a removable plastic sheet, similar to mylar, that i'd place down there.
Anyone else have any ideas?
#1445 6 years ago
Foto/Frisket Film cut to size. Get a roll or 10 sheet pack on amazon and it will last you forever.
#1446 6 years ago
I've seen the Frisket stuff used in threads when people are redoing the cabs, it never occurred to me to use it like that. Easy enough to pick up on amazon.
Oh and why do people seem to dislike mylar so much?
#1447 6 years ago
Thanks everyone
Really enjoying this pin, easy to learn, hard to master with that "just one more game" addiction.
Really happy with the condition also. here is some more photos
#1448 6 years ago
two more
#1449 6 years ago
mine is possessed! as the ball goes to the inlane ,an apparition pulls it into the outlane, EVERY TIME!!!! wth!
#1450 6 years ago
Quoted from yoshootme:
Does it make you feel like a blundering novice?
$ 50.00
$ 109.99
$ 279.95
Pin Stadium Pinball Mods
$ 90.00
Lighting - Under Cabinet
$ 45.99
Lee's Parts
