(Topic ID: 29878)
Bram Stokers Dracula Club....Welcome to the Carpathians
By shacklersrevenge
7 years ago
  • 7,139 posts
  • 587 Pinsiders participating
  • Latest reply 7 hours ago by gearheaddropping
  • Topic is favorited by 226 Pinsiders
There have been 2,200 images uploaded to this topic. (View topic image gallery).
31 key posts have been marked in this topic, showing the first 20 (Show topic index)
There are 7139 posts in this topic. You are on page 102 of 143.
#5051 1 year ago
Is a 12697-3 driver board compatable with BSD?
#5052 1 year ago
Hello guys, I would need to print waterslide decals for the "love never dies", 2x and 3x insert decals.
Someone already did this job?
If you could share the files or at least scan those parts of the playfield you would help me a lot!!
Thank you very much!
#5053 1 year ago
Hi guys,
Today I’m going to buy a nice BSD, what should I check on this machine, before I take it home?? Dmd shows some garbage though...
Gustavo
#5054 1 year ago
if you already know you're bringing it home, what's the point of checking anything? price negotiable or something?
#5055 1 year ago
Yeah price its negotiable, $2.500, any weakness on this machine? Its working but need to reconstruc flippers, new rubbers, balls etc. Its been on storage many years!!
Gustavo
#5056 1 year ago
boards: battery acid, burnt GI connectors, hacks. playfield: shooter lane, insert wear, planking (including right orbit where the ball drops off the shooter lane, rat and mystery holes. cabinet fade; translite. fire all the coils and flashers in test. replacing resistors and transistors sucks.
#5057 1 year ago
Thanks your your feedback, will post pictures as soon i get it.
Gustavo
#5058 1 year ago
That playfield looks pretty nice in the ball drop and lightning bolt areas.
#5059 1 year ago
Full magnet test.
#5060 1 year ago
Hi everyone I have not been on pinside for a long time but just got a BSD on Sunday and love it. Not sure if I need to ask a mod to become a part of this owners section (no idea how it works) Anyway my only problem right now is my ball launch is somewhat inconsistent. I'd say it'll rattle up the lane and short plunge or not hit the drop target and just go through a top lane maybe 3 out of 10 or 15 launches. Any advice?
#5061 1 year ago
Quoted from PhillyBilly:
You just joined the club. Congrats!
Do you have the clear square plastic above the shooter lane right in front of the ramp? If you do, is it pointing toward you? It should be.
#5062 1 year ago
Quoted from aobrien5:
I do not. I am assuming it would be right past the metal ramp at the beginning of the plastic ramp with the screws on either side... nope nothing there. I saw a wire kind of hanging barely in the lane under the castle lock ball hold/release and seems to have helped. 1 weird plunge out of about 20 or so. Thanks!
#5063 1 year ago
I have noticed something also strange, instead of saying "REPLAY AT 299,000,000" on the DMD while in playing a game (typically between ball 2 and 3) it says "BALL 2 299,000,000" is that supposed to say that? I figured it would say "replay at"
can I change that?
#5064 1 year ago
Here you go, get a new one. The other clear plastic prevents rejects from the right ramp, so make sure you have that one too.
https://www.etsy.com/listing/173278432/bram-stokers-dracula-pinball-clear
#5065 1 year ago
can I change that?
Never noticed that one. It doesn't really seem like something you could make a setting to change. Pics?
#5066 1 year ago
my ball is not jumping up at all when I launch it so for now I do not think i need that shooter lane plastic and I have the coffin ramp plastic already on there.
#5067 1 year ago
Hi guys,
So the restoration begins, playfield in good shape, its a SP. All boards running and no corrosion from the AA batteries, just an strange issue with the sound, its extremely loud, volume control seems not working, one backbox speaker not original and sound board looks fine!! Any ideas?
Gustavo
#5068 1 year ago
And more finds, long bean 24" opto board is dead, +13V is there and led is off, I've re soldered all points but nothing, caps seems fine though. Help here......
#5069 1 year ago
Homepin sells a replacement board.
#5070 1 year ago
So there's no repair on this one?
Gustavo
#5071 1 year ago
Quoted from Haggy38:
Gustavo
Much more reliable just to replace the board. Homepin's is solid.
#5072 1 year ago
Damn it! Usd$90, should I order new optos as well, Tx and Rx?
Gudtavo
#5073 1 year ago
Gudtavo
https://www.pinballlife.com/index.php?p=product&id=4362
The optos usually won't be required.
#5074 1 year ago
Thanks, any idea why the sound it's extremely loud? Can't turned down with the coin door buttons, is a volume potentiometer somewhere else?
Gustavo
#5075 1 year ago
Gustavo
There is a volume override for minimum volume setting - somewhere in the menu.
#5076 1 year ago
Sure, it can be repaired if you want to go through the effort. I would start another thread if you want to go through troubleshooting the board since it may take a few posts. Post the link here or PM me if you start a new thread.
#5077 1 year ago
The only thing worth trying is have a close look at the choke on the board. It has very fine wires that break off. You can scrape back some of the coating and attach a new wire if you find a broken wire.
Also replace the electro cap on the board. They can leak and cause issues.
If those things don't fix it I'm afraid there is little else can be done as the main IC is simply not available and the rest of the parts don't give any trouble.
#5078 1 year ago
Thanks guys for your feedback, so I ordered a new one to avoid future failures. I found the volume override on the menu, but is not lineal and the left speaker(original) is dead, the right one is 4ohms but unknown W, the cabinet one(original) is working, any options? I already ordered parts for $300, plus opto board $100...... empty pockets now. Anyone here got the original ones in good shape? Willing to pay for them....
Is this wiring ok??? On schematics shows J505 pin 2(black-yellow) and J504 pin 3(black)
#5079 1 year ago
I am relatively new to working on Pins but I have some knowledge... I just played a game and when the ball goes into the mystery/mist MB it will sometimes kick out into the right inlane as it should, or sometimes it takes an extra 4 or five seconds or it will have to do a ball search. What should I be looking at or checking? Thanks in advance. It will register mist MB and mystery just fine and I can hear the ball get all the way into the VUK and that is where it sits or launches up depending.
SOLVED: I think I did at least. I took out the opto for the VUK and gave it a cleaning and then tested it with the game on while they were out of the VUK. They were working every test and then put them back it and seems to be working fine now. Glad it was so easy...for now.
#5080 1 year ago
Well guys,
Great news, a fellow member here contact me and its going to send me the original speakers, I really appreciate this gesture. I live in Bogota, so you guys understand how difficult and expensive is to restore these machines.
I really love this place, will post more photos of this beautiful project.... Cleaning, cleaning and more cleaning
Regards,
Gustavo
#5081 1 year ago
So my first coffin lock just started staying half lit or dim, but it’s on all the time. It fully lights when lock one is triggers. Amy ideas to fix? Change out for non ghosting bulb maybe? All my lamp fuses are fine.
#5082 1 year ago
Yeah, it's ghosting.
#5083 1 year ago
I presume you don't have non-ghosting bulbs? If so you really should change them all out to non-ghosting. The bulb that is coming on all the time is not necessarily the bulb causing the ghosting. Plus I would suspect you have more ghosting than you realize.
#5084 1 year ago
So the project is looking really good, what do you think guys.....
One question I would like to use a couple of LEDs of n the playfield, blues(sling shots) and purples on the sides, the rest the original lamps, I really like the warm yellow as been designed. What type of leds do you suggest and where can I get them? I guess to replace some 555, 44 and 89 flashers. Thanks
Gustavo
#5085 1 year ago
Gustavo
I have been using a lot of Blue, Purple, and limited green and red and 2 amber to the right of video inserts. Also lit up the grave yard with a 4 inch green LED strip. I HIGHLY RECOMMEND comet pinball. The product is great along with the service and fast shipping. Heck They'll probably ship your order today if you order soon. I am about to put an order in myself.
#5086 1 year ago
Gustavo
You're on your way! Next, get those flippers cleaned and post rubbers changed!
#5087 1 year ago
Thanks, theres lots of different ones, any one in specific ? Thanks
Gustavo
#5088 1 year ago
I ordered a complete reconstruction flippers, new coils, new bats and rubbers!!
#5089 1 year ago
What a beautiful view, an undamaged, unrepaired CPU Board with original ROMs ........
#5090 1 year ago
This mod is amazing!! I guess 12v green led strip?
#5091 1 year ago
Wow that looks so nice!
#5092 1 year ago
Looks like glow in the dark or UV paint.
http://www.cometpinball.com/category-s/1845.htm
#5093 1 year ago
Gustavo
EH, I kind of ordered a hodge podge and tested different ones until I liked what I had. Non Ghosting in your coffin lock sockets, and purple passions are really nice.
#5094 1 year ago
Well this mode is from here, it's just a 12v green led strip...
#5095 1 year ago
I kind of did something from similar but I put a 4inch green LED strip from comet above the graveyard.
#5096 1 year ago
Wow that looks good too!
#5097 1 year ago
Ok guys,
I need advice here, this is what I got so far...
1. Right side Dracula is purple OPTIX MAXIMUS 44 and Row Tower 89
2. Left side Lucy is orange OPTIX MAXIMUS 44 and Row Tower89
3. Slingshot and drains is blue OPTIX MAXIMUS 44
And some blue 906 LIGHTHING effect. Still want the uv coffin mode, any one has this mode?
Gustavo
#5098 1 year ago
Ok guys,
Gustavo
Im usually one for color led's but try some clear white's down near the slings & flips. Pretty dark game and you might want some extra light down there.. you will know once you get it back together what YOU want there..personal pref. I wish my playfield was in the condition of yours!!
#5099 1 year ago
Quoted from Dee-Bow:
Thanks, this pin was left in a corner for years at Harley bike bar in Medellin, I was very lucky that no one messes with her. I'm trying to save money to buy his companion..., a T2 in regular shape but restorable..... I hope.
#5100 1 year ago
i don't like regular blue LED's; washes out the artwork too much. comet ice blues are a must. i'd stay away from orange, too; same reason. stick with purple for the top 2/3's of the playfield. reds under the top lane guides, pops and coffin locks. natural white flashers and under inserts. sunlight white in the backbox.
miss my BSD, if you can't tell.
Medisinyl Mods
