Often when people remove the caps, they also pull out the through hole conectors - these traces that you see connect the cap to the bridge rectifier (as do the normla traces on the top side of the board), so if the through hole connectors were damaged, it minimises the chances of issues - particularly resets.
^^^^This^^^^^^^^
The caps have a twisted leg on them, often they pull the eyelets out with the caps. Then you have to jumper it. As far as hacks go this is nothing to worry about.
Got it.... thanks.
Anyone know where I can pick up a reliable board when this one fails?
I'm not opposed to a new board.
It was having reset issues. That problem seems to be gone now that I've changed out the capacitors .
But I'm getting balls doubling up in the shooter lane so I'll have to look at that.
Test says
switch 15 left drop target
Switch 17 shooter lane
Magnet error
Back in May I too got a BSD and it was hacked similarly with a reset issue. That is one of multiple hack's and I'd rather not talk about the money pit on my hands right now, heh. The board I was told was possibly repairable by friends. When I brought it to Pintastic I wasn't surprised "Aardvark Pinball Restoration" told me to trash it however. They said the carbon soot etches the board and carbon is a great electrical conductor. Plus it was on fire which certainly isn't good for electronics. I would certainly get a Rottendog board from K's Arcade. He is a pretty good guy and I live near him and is very professional with his home/online store. Judge with the pics yourself but you won't have to worry about caps bursting, reset issues, the pretty layout, less lower consumption so less coil humming, etc, etc, etc.
I'd have to put Dracula in my top games as far as playability and fun. I knew there'd be problems down the road when I got it because it was cheap so I can't be upset with the minimal problems it's having now.
I just want to get it back in shape again so I can continue playing.
I'll definitely look into a new board at some point.
Thanks for the advice.
This page was printed from https://pinside.com/pinball/forum/topic/bram-stokers-dracula-board-hack and we tried optimising it for printing. Some page elements may have been deliberately hidden.
