(Topic ID: 257002)
bram stoker dracula assylum upkicker makes a metalic clunk
By wugly
74 days ago
  • 5 posts
  • 4 Pinsiders participating
  • Latest reply 74 days ago by wugly
#1 74 days ago
my assylum upkicker always seems to make a metalic clunk when a ball goes in and a lot of the times when it comes out. there is a rubber stop at the bottom for the plunger to rest on. the ball hits the sides of the scoop and makes a clunl going in and I think it hits the scoop on the way out and clunks sometimes. is this normal and if it is not how would I adjust it to remove the clunk
#2 74 days ago
Mine had that too. Myself? I love the satisfying clunk it makes.
#3 74 days ago
I don't think that it's rubber on the end of the plunger, I believe it's metal and they do break off and then "float" on top of the plunger, double check it, super glue will not hold it, you need to buy a new plunger, PBL has them.
#4 74 days ago
Is that upkicker coil the correct coil installed?
#5 74 days ago
correct coil and the rubber is not on the plunger it cushions the plunger after it shoots the ball and drops back down. if I press down on scoop I think it keeps metal from ringing
$ 399.95
Pin Stadium Pinball LEDs
$ 109.99
3,400 (Firm)
Sale Pending!
Albany, NY
$ 63.50
