Just bought an Eight Ball Deluxe, love this thing, but it's my second non-Williams type flipper issue.
I started my discovery with the Meteor, and discovered the NOC closed nature of the EOS switches. And also the way they put a piggy back on the first flipper instead of on the flipper switch the way Williams games do.
Now, I'm playing with the EBD, and the upper flipper is acting weak, and the left flipper bounces sometimes. You'll hit the button, the lower left flipper will come up, but sometimes it "bounces". It seems like if the ball hits the extended flipper hard enough, it'll cause that "Bouncing" behavior. If it were a Williams game, I'd think the EOS needs to be cleaned, since the secondary isn't getting enough power. In this case though- I can't figure it out.
ALSO- Since the upper flipper was acting weak, I decided to change the coil sleeve. However when I took the old one out, it was unlike other sleeves I've seen. There was no bottom flange on it. I have always taken standard sleeves and cut them down to whatever size the application requires. Does anyone else do this? Are there problems with modifying them? I can't see how, but please. Someone fill me in on this coil sleeve mystery!
The upper flipper also had an unusual mechanism - other than the way the NOS EOS switch is, this has a brace, that the extended rod slides through to keep the rod straight. WHat's up with this? If it's such a great idea, why don't all the flippers use the same holder for that extended rod?
Oh! Another thing!! I notice the coil base- or whatever you call the metal piece is copper instead of a ferris material the way the ones on other pinball machines are..
Someone please tell me ALL the differences between Williams Flipper coils and what seems to me to be very foreign Bally flipper coils, and mechanics? I was going to say that I don't recall older Bally games having Noc EOS switches, but come to think of it, the EOS on my Honey are NOC. Is there a story as to why they went with series wound coils in some cases, and dual wound in others?
-Brian
