I took my Fliptronics II board out to try it in my WH20 (where I ended up having a bad transistor) and when I put it back in TZ the flippers do not now work in play, but when I go to flipper test in the diagnostics they do.
When I go to switch test and press on the flipper buttons, they both do not register on the matrix.
If I close the flippers manually the EOS switches register.
I swapped in the (repaired) Fliptronics board from WH20 and no luck. I also swapped in an opto board and that made no difference either.
So it doesn't seem to be a flipper opto switch board or a Fliptronics board issue.
Any ideas where to go from here?
