New! Dark mode!
(Topic ID: 183390)
Bop_Switch Matrix
By Devilsmuse
  • 62 posts
  • 6 Pinsiders participating
  • Latest reply 3 years ago by GRUMPY
There have been 26 images uploaded to this topic. (View topic image gallery).
There are 62 posts in this topic. You are on page 2 of 2.
#51 3 years ago
Sw.34 reads .514 and OL the other way. Sw.54 reads .546 and OL the other way . Stripes are all going the right way.
#52 3 years ago
You may have two bad switches. Pretty rare, but possible. Jumper from the banded side of the diode to the Normally Open lug. That will also test the diode at the same time.
#53 3 years ago
Quoted from terryb:
Terryb, I jumperedested it from band side to the NO lug and nothing happened in the switch edges test.
#54 3 years ago
Quoted from Devilsmuse:
That's odd. Are you sure the diodes aren't reversed?
Post some photos of those two switches.
#55 3 years ago
Terry I mispoke I typed sw34- I meant to type 51. The switches in question are 51 and 54.
I took pictures of 51 and 54 and here are the switches you can see the diodes....
#56 3 years ago
Diodes look correct, but I see a lot of other stuff I don't like. The good news though is you now know the problem is right in that area.
In the first photo the diode should not be in-between the playfield and the switch. Who knows what it could be touching, or the lead even broken. The solder joints aren't horrible, but not good either. I've never seen a switch quite like that and can't tell which is the NO lug and which is the NC lug. You could check that to common with a meter.
In the second photo the copper piece that the green wire is soldered to shouldn't be curved around like that and looks like it could be touching the other copper piece. Solder joint on left is not great and the one on right could be a cold joint. I would compare the lug connections to another leaf switch and make sure they match. Added image of leaf switch connections below (wire colors are different so go by row and column labels).
I would probably replace both switches and wire them up cleanly.
Another test you could do on the switches is (game off and meter on continuity) one lead on common and one lead on normally open and make sure you get continuity when you manually close the switch.
#57 3 years ago
Thanks I'm going to give that a try. Stay tuned...many thanks
#58 3 years ago
Terryb, While I am waiting for parts to arrive. I wanted to show you the spinner switch. You said you hadn't ever seen one quite like this. See if this makes any sense to you. I am confused. Theoretically can this even function as a switch in the switch matrix?
#59 3 years ago
OK, it's just a cherry switch. That piece of fiberboard was confusing me.
The third lug (the one with the diode and the wht/xxx wire) is not electrically part of the switch circuit. It's just a place where the wire and the diode can be soldered.
Since you've got it all apart check the switch with your meter (game off, ohms setting) and see if it works.
#60 3 years ago
This is wired correctly. Check switch as Terry said and check the diode too.
#61 3 years ago
Well I have good news. I replaced both sw.51 and sw.54 and it works! I can't say which was bad , probably a solder break , because the diodes and switches checked out when I pulled them out of the machine but I replaced them anyway. I redid all the wiring and soldering..... "She's Alive!" I_B_BOP_in Tonight! Thank you Mr Grumpy and a big thanks to Terryb , I learned so much trying to fix this problem- I not an expert but I do now know my way around the switch matrix. Cheers! I am so Happy!!!!!!!!!
#62 3 years ago
I_B_BOP_in Tonight!
Arcade Upkeep
$ 54.99
$ 79.00
Lighting - Under Cabinet
Arcade Upkeep
DevilsMuse Arcade
