(Topic ID: 183390)
Bop_Switch Matrix
By Devilsmuse
7 years ago
  • 62 posts
  • 6 Pinsiders participating
  • Latest reply 7 years ago by GRUMPY
There are 62 posts in this topic. You are on page 1 of 2.
#1 7 years ago
I have a switch problem on my Bride of Pinbot. I have been following the test procedures of a really great article on switch matrixes by Pinballrehab http://www.pinballrehab.com/1-articles/solid-state-repair/repair-guides/146-switch-matrix-theory-and-troubleshooting#comment-362
So far I have checked the CPU board by using the jumper test on J209 and J207
I have confirmed continuity of the send and return wires of the switch matrix column 5 grn-blk.
I have tested the switches and diodes for continuity and this what I have found
Note, in my testing I first tested across the switch the send and return terminals and keeping the test leads in the same position tested the diode. I then reversed the test leads and tested again across the switch, then across the diode and recorded the results.
Column. Across switch. Across diode
SW # 1st/2nd. 1st/2nd
51 spinner. Y / N. N / Y
52 shooter. Y / N. Y / Y
53 Ur jet bmp. Y / N. N / Y
54 Ul jet bmp. Y / Y. Y / N
55 low jet bmp. Y / N. N / Y
56 jet sling bmp. Y / N. N / Y
57 left sling shot. Y / Y. Y / N
58 right slingshot. Y / N. N / Y
Any help interpreting my test results would be greatly appreciated.
#2 7 years ago
Quoted from Devilsmuse:
You mention the column line, did you also test the row for continuity?
Which switch(es) are not working?
#3 7 years ago
Am I understanding correctly that Y = continuity and N = no continuity? If so then switches 54 and 57 and stuck closed. The diode on switch 52 is shorted. Also the diode on switches 54 and 57 are installed backwards. Maybe when the diodes are reversed the switches 54 and 57 will not show closed all the time.
#4 7 years ago
Quoted from terryb:
I tested the return lines or row ( if I am understanding correctly) from switch back to the j209 (ie wht/green ) and there was continuity on all. The game used to tell me switch 54, the jet bumper is still not working. The other switches 57 ,left slingshot seem to be working but I cant tell by playing if one of the two of them is not-it still kicks out the ball. The shooter switch may or may not be working I am not sure what it does.
#5 7 years ago
Quoted from GRUMPY:
You are understanding correctly Y=continuity and N=OL no continuity. Grumpy everything you say could be the case. The electronics could very well be that messed up backwards and shorted. I bought this game as a "players game" and am restoring it for my own small collection. I have no idea how many owners it has had or who worked on it.
#6 7 years ago
Then remove the diode on switch 52 and retest it, then replace it. Its only .05 cents. Check the diode band on 54 and 57 and see if they are going the correct way.
#7 7 years ago
Quoted from GRUMPY:
Sounds like a great plan. I am going to give it a try and let you know how it goes. Thanks
#8 7 years ago
You want to check the row wire (wht-yel) back to J209 and the column wire (grn-blk) back to J207.
How the switches should be wired.
#9 7 years ago
A pic is worth a 1000 words!^^^^
#10 7 years ago
We are without power going on day 4. I will get back to you both once day light comes.
#11 7 years ago
Quoted from terryb:
Terryb, I finally tested the row 4, wht/yel this morning. Still no power but we have daylight!
Everything checked out for continuity, except for switch plumb bob tilt #14. I am not sure how to test it besides putting the test lead on the wht/yel wire connected to the plumb bob ring.
But get this is there something wrong with this picture of switch 58?
#12 7 years ago
Looks OK to me... what am I not seeing?
#13 7 years ago
The diode crosses over the switch gap , comparing it to the other switches of this kind the diode should be connected to the center tab , not the outer one, as it now. I am not an electrical expert or claim to be anything even closed, but but with the switch wired like this doesn't it allow the flow of current even though the switch isn't closed?
#14 7 years ago
Also another note about that switch the green black wire should be on the outer far left tab , right now both the send and return are on the same side of the switch.
#15 7 years ago
If you look closely each tab on the switch is an individual piece of copper separated by fiber insulator block. The white wires are connected to a tab that doesn't have switch contacts at all, its there just for a connection point for the diode and the wire so not to be floating in the air.
Quoted from Devilsmuse:Also another note about that switch the green black wire should be on the outer far left tab
You can put the green wires on the left, but then you would have to move the diode lead to where the green wire is now. Just look back at Terry's pic of the switch, white wire---diode non band---switch contacts---green wire.
#16 7 years ago
Ah thanks Grumpy for the explanation, makes sense now. That switch was wired differently from the other two so I was hoping if it were rewired like the other two it would fix everything.
#17 7 years ago
Maybe the problem is with the other two.
#18 7 years ago
So you get continuity from J209 to switch 54, but not to switch 14? Does switch 14 work in switch edge test?
I'm with grumpy in that you may have multiple problems. It probably wouldn't be a bad idea to go into switch edge test and test all switches.
#19 7 years ago
Progress report , I re-jumper tested the j209 and J207 pins on the CPU board during switch edges test and everything checks out. During switch levels test I came across a closed switch, #67 Face position. I don't want to be a chicken little again , like the slingshot switches yesterday please check out the wiring on the #67 switch.
#20 7 years ago
This switch contradicts that really cool diagram of switch wiring that Terryb so gratiously posted.
#21 7 years ago
That one is wired as 'Normally Closed' and 90% sure that's correct for BoP's head.
#22 7 years ago
Hmm during switch test, it comes up as sw#67 (A) closed. Blinks and makes a sound like it's giving me the bird. Could it be a bad switch as opposed to it should be normally open?
#23 7 years ago
Switch #67 is normally closed on BOP.
#24 7 years ago
Thanks Pinwiz I will just keep searching then
#25 7 years ago
I have tested all the rows and all the columns everything has continuity that I have been able to test. Let me clarify some switches I cant get a reading but I am not sure why the flipper switches 11,12, coin door closed 22, start button 13, slam tilt 21, ticket opto 23, basically anything in the cabinet I am not getting any Ohm readings. Is there a trick to testing these switches? I also should mention that this is not the machines original coin door but looks like every thing is there.
#26 7 years ago
They should test the same as any other switch that is part of the matrix.
#27 7 years ago
Quoted from terryb:
Oh boy I think I have problems then. I dont know how to begin to show you , other than take pictures of the switches and see if you can tell why I am not getting any continuity (either row or column). I am testing with the game off and the connector J209 ,J206 disconnected from the cpu board.
#28 7 years ago
Here are some pictures of the switches/ areas. Let me know if it makes any sense to you ,please.
1489545103945-1145533895 (resized).jpg1489545103945-1145533895 (resized).jpg
#29 7 years ago
I also just noticed "cabinet switches" J212 and "direct switches" J205 connectors on the CPU board. I need to test these? Do these have the same relationship , column/row that j209 and j206 have? Can these be jumper tested also? Thanks I am such a noob.
#30 7 years ago
The dedicated ground switches are not part of the matrix and work differently. No need to test them unless you're having trouble with those switches. The reason we want to test all of the switch matrix is to aid in troubleshooting since they are interrelated.
I didn't spot anything in the switches, but maybe someone else will (can't see images on the computer as good as I used to). I would be suspicious of a connection problem at the interconnect board since both row and column don't work for those switches.
Get the schematics out and make sure each connector is in the correct location and not installed one pin off.
#31 7 years ago
Quoted from terryb:
So the interconnect board is the board on the inside left side of the cabinet, Last picture of my previous post? How would I test it? Check the continuity from the backbox to the board?
#32 7 years ago
The board in the last picture. You can see the labels for col 1, row 1, etc. Make sure connectors are installed properly and then you can ohm to the cpu connector or the board if the connector is installed.
#33 7 years ago
Hello, I have retested ,very thoroughly and methodically all the rows and columns from the back box to the playfield and to the interconnectivity board A-14102 for continuity and everything checked out. I got out the schematics for th interconnect board and confirmed the correct wires went to the correct pins. Th only abnormality I found on pin 7 of J6 connector had a grn/red instead of grn/brn going to th plumb Bob tilt switch #14. This is of no consequence since row one still connects to as #14.
There was only one switch I could not find to test, switch 23 ticket opto, everything else has been tested for continuity and passed.
I don't know what to do next? Check the diodes? Also I am curious about whether the Pinitech WPC Reverse Switch tester would be a good thing for my problems. I understand there are a few still available. I might be able to snag one.
#34 7 years ago
So 11, 12 and 13 don't work. Do 14 through 18 work? If so that would indicate a break in the column wire. Check for continuity on the grn/brn wire on switch 11, 12 or 13 to one that works (14-18).
#35 7 years ago
I have continuity on 14-18. Switches 11,12, I can't find on the matrix . The flippers are wired separately and those heavy gauge wires go directly to the power driver board , connector J109. There are no grn/brn or wht/brn or wht/red wires from the switch matrix present at the flipper switches. From the interconnect board I was able to test and confirm continuity for the matrix switches ,21,22,13,14, but no flipper switches 11,12,or ticket opto 23, listed in the switch matrix.
#36 7 years ago
There is 2 cut wires I see.
#37 7 years ago
Those cut wires are "ctr coin 2", pin 5 and "rt coin 3", pin6 on J3 . I don't know if they matter, this is not the original coin door I was told it was from another machine, meaning it didn't match the original. So when I first saw them I discounted them as meaning nothing but maybe they do?
#38 7 years ago
Do they work in switch test. Some of the continuity readings just don't make sense so I want a second perspective with the switch test.
Switches 11 and 12 are probably the lane change switches. Either installed as a second switch on the flipper buttons or as a second switch on the flipper mech along with the EOS.
#39 7 years ago
Terryb, just checked 14-18 and they come up working as well as 11, 12, 13. While I was at it I tested all the other switches of the matrix and the only two that don't register at all are 54 UL Jet bumper and now 51 spinner.
#40 7 years ago
Terryb , I believe the post above is causing confusion, my fault. I posted this before I knew anything about J212 on the cpu board. After, with your help, I figured out how to test these send and return lines. I successfully got continuity on the grn/brn and grn/red send, from cpu to the interconnect board and from the interconnect board to all those cabinet switches. The same for the return lines wht/brn, wht/red, wht/org, wht/yel.
So I ran the switch test and every switch was accounted , except 54 UL Jet bumper and 51 spinner. This morning I checked continuity on column 5, grn/blk and row 1 wht/brn trying to diagnose the spinner 51 and there is continuity everywhere. This is driving me nuts- lol I am going to recheck the header pins/connections J212, J209, J207 next.
#41 7 years ago
Check switches 51 and 54 and see if there are one or two column wires and one or two row wires on each switch. If those switches are at the end of the line a high-resistance connection (usually at the IDC connector on the cpu) can make switches that are farther down the line not work, although they will pass a continuity test.
Also provide photos of the row and column connectors on the cpu.
#42 7 years ago
Terryb, switches 51 and 54 both have two row wires and two column wires .
FYI , the switches in the row 1 , that only have one wire is sw.21 slam tilt( cabinet switch, one white and one grn, they all have just one wire row and column) and sw. 31, skill shot 50k (one wht/brn wire).
The switches in row 4 with one wire are sw34, one white and two grn/blk,and above playfield sw.64, 74 have one grn and one wht running to them.
Column 5 is the easy one just one switch #52 has one grn/blk and one wht/red wire running to it.
And now for the pictures.... note the cpu board that has been jumpered. I tested the header pins yesterday and they all passed.
#43 7 years ago
The CPU has some questionable solder joints. Both of the ones I circled in red look like they could be touching another joint. Or it could just be the angle of the photo, but I would check both of those. The lower left circle is a cold solder joint and should be redone. I don't know that this is your issue, but the jumpers should be cleaned up at some point.
Do you have a logic probe? Do you have another cpu board you could swap in?
#44 7 years ago
I do not have a logic probe, andI do not have a cpu board to swap out. I checked my Creature from the black lagoon and the boards don't match.
I was thinking of sending this board out to have it tested and have a NVram and socket installed while it was being looked at.
I am also wondering if its time to be testing the diodes or since the continuity test are all checking out- its time to check the cpu board?
#45 7 years ago
This test verified the cpu board is working. Although as I mentioned earlier a high-resistance connection can cause switches at the end of the line to not work.
I would definitely test the diodes on the two non-working switches.
Also jumper across the switch and see if it is then sensed as being closed. Jumper from NO to NC.
#46 7 years ago
I had a very similar problem a while back with my BOP.
After months of struggling it was corrosion inside the mini connector that went to the CPU board.
I repinned/replaced it and all is still fine.
I could only see the greening inside after I took a flash pic and blew the pic size up.
I'm going to find you the thread.
https://pinside.com/pinball/forum/topic/bride-of-pinbot-motorswitch-issue#post-3244894
#47 7 years ago
Also jumper across the switch and see if it is then sensed as being closed. Jumper from NO to NC.</blockquote
Terryb, as I have said before I'm a noob. NO to NG?
#48 7 years ago
Sorry, Normally Open to Normally Closed terminal (see the image I posted earlier in the thread).
#49 7 years ago
Quoted from CUJO:
Thanks I will take a much closer look, thanks I really appreciate everyone's help on pinside.
#50 7 years ago
Quoted from terryb:
Well jumpering NO to NC works! Both 51 and 54 closed. Checking the diodes now. I am going to resolder one leg to get the readings.
$ 69.00
Pinball Pimp
$ 250.00
Professor Pinball
$ 399.00
3,700 (OBO)
Memphis, TN
$ 1.00
Mitchell Lighting
$ 1.25
Mitchell Lighting
DevilsMuse Arcade
$ 27.95
$ 200.00
Professor Pinball
$ 1.00
Mitchell Lighting
+CY Universal
$ 9.99
$ 170.00
Displays
Digipinball Shop
$ 9.95
$ 9.95
Albany, NY
£ 69.00
PinballToys
£ 58.00
PinballToys
$ 44.99
Pinball Shark
Westminster, MA
Great pinball charity
Pinball Edu
This page was printed from https://pinside.com/pinball/forum/topic/bop_switch-matrix and we tried optimising it for printing. Some page elements may have been deliberately hidden.
