I've repaired a WPC driver board with blown fuses and transistors and also traced back from Q50 to the coil it powers, solenoid 13 "Lower Jet Bumper". Checking the resistance on the coil shows 0.5 ohms unlike the neighbouring Jet Bumpers which read 10.3 Ohms. I believe that means the coil is bad?
This might be a bit of a silly questions, but... how do you actually remove the coil? As the image below shows, there's a plate that's holding it in place, but the jet bumpers all appear to have extra long screws which prevents the socket reaching the nut. Are screws this length normal on williams jet bumper coils?
Can the plate screws be accessed from the top side of the playfield if I remove the bride helmet, various plastic parts and the bumper top? As that's quite a lot of items to remove, I'd rather not do so if the plate screw isn't actually accessible there.
Anyone have this machine? If so, is there an easy way to remove this coil that I'm overlooking? Or does everyone just buy a socket set that's extra long to fit over these screws?
