BoP is going under the knife. Not sure if you can reuse the siderails or not?
Are they just double-sided taped on like the newer WPCs or not?
Are they taped on or just bolted?
I would buy a new set, but I can't see anywhere that sells them....
I think I got em at PinballLife. It's hard to cross reference the part number since it is a unique side rail.... let me look up my order...
I've just heated the side with a heat gun and used a very wide drywall blade to cut thru the tape. No dents or creases and only takes a couple minutes at best to work from the front to the back
OK, I'm a dork. I was thinking you were talking about the wood rails on the PF. I just pulled mine off. Took a heat gun and a thin drywall blade as well for mine.
Would these not work though as a replacement http://www.pinballlife.com/index.php?p=product&id=822
Quoted from 85vett:Would these not work though as a replacement http://www.pinballlife.com/index.php?p=product&id=822
Not the right set. These are the ones for BoP...
This page was printed from https://pinside.com/pinball/forum/topic/bop-siderailscan-you-reuse and we tried optimising it for printing. Some page elements may have been deliberately hidden.
