Bop outlane kicker problem
By Nesta08
1 week ago
Stats
  • 6 posts
  • 2 Pinsiders participating
  • Latest reply 1 week ago by tfduda
Find
Search this topic for posts matching certain words or written by a specific Pinsider. Or both!
#1 10 days ago
So I just finished my 1st full restoration on the game my collection started with. Bride of pinbot. Fingers crossed I turned her on and success back to life. Have a issue however. Game has 2.0 kit installed. When the 3rd ball hits the outlane kicker assembly and the coil fires the ball enters the trough only to bounce back into the kicker assembly and keeps going back and forth. I can go into the adjustment menu in 2.0 setup and lower the coil pulse and the problem goes away. But once I switch back to version 1.0 the problem resumes. Any thoughts??? I checked the mounting position on my old playfield and everything appears to in the exact same position. This problem did not exist prior to disassembly.
#2 10 days ago
If I understand correctly, I had a similar issue when disassembling components near the outlane and I think it had to do with how a wire gate (see below) was positioned. The picture below should have the correct orientation of the gate (outer bit to the right of the little outside nub) to keep the third ball in proper place after the coil fires it (or at least this is how mine looks now—I did move it the other way around and get similar symptoms as I had before). Hope this helps.
#3 9 days ago
Thanks for the input. Your spot on! My trough is missing the gate. And without it the 3rd ball bounces back. Whats weird is this just started. And I know the gate was not there before..... Any chance- tfduda you can measure what you have and I will have to make one up.
#4 9 days ago
Ok. See photo. I don’t have good calipers at home and so the measurements are best approximates based on a Stanley tape measure. Close enough I suppose... Good luck!
#5 9 days ago
Thanks !!
£ 69.00
PinballToys
$ 209.99
KAHR.US Circuits
$ 40.00
6,900 (OBO)
Alpharetta, GA
Wanna join the discussion? Sign up for a Pinside account, or log in if you already have an account.
