I have an issue with one of the chase lamps not working on the helmet of my BOP.
I've ruled out the bulb and bulb socket as being the issue. The board looks nice and clean and the traces appear perfect. The bulb works when hack/hotwired to the next bulb over.
I think that what's going on is that each bulb has a diode associated with it, and the board uses a common ground for all the bulbs. I think that the diode with this particular bulb is bad.
Does this seem right?
Is that really a diode? I have no idea how to tell a diode from a resistor from my elbow.
Can I just replace it? and what size/spec should it be?
Thanks.
