Quoted from jsa:I don't suppose you have a photo of the original metal plates? I'm trying to understand better why CPR would say you don't need them, which doesn't make any sense to me.
Here you go.
I'm sure it will work with the new CPR plastics. The problem is that it doesn't look right. The plungers for the eye are pointed, and the eye holes are larger. So when the ball falls into the eye hole it rolls off center.
The original hole, and plate was designed to capture the ball, as you can see in the one picture of the original, the eye hole just let the pinball through, the plate just held the ball.
It would be possible to use the original plate, but since the hole is a large oblong shape, the pinball will roll towards the inside, causing the bride to look cross eyed.
I didn't like that option either. So I made individual holes the same radius as the original, but made it where you could mount it with the posts, which remains to be seen how well it will hold up since the screws are just held in by the plastic posts. But I have provisions to allow mounting the original screws to help hold it together jic.
