Quoted from sd_tom:What you described will basically recreate bop2.0 as you have to replace the same stuff they did to get a dmd running but with used boards. It's not going to be a lot cheaper when you factor in time/labor, Plus paying for programmer.
Wouldn't you only need the DMD and DMD driver board added to your existing board set? This would be significantly cheaper. I was kind of thinking of it more as a fun hobby project. (Not paying a programmer, doing it yourself type of deal). Basically it would be BOP 1.0 with DMD graphics. Not really interested in 2.0 sound or rules.
Main reason I ask, is because I have thought about this, I do a lot of programming, and was wondering if anyone else had thought about doing this or has attempted to. Was pretty fascinated by the work done with the new Demolition Man code in FreeWPC
