Has anyone installed the LED OCD boards for bride. I just did mine and now my helmet doesn't light up anymore.
Quoted from SuperPinball:Has anyone installed the LED OCD boards for bride. I just did mine and now my helmet doesn't light up anymore.
Contact herg.
Aside from the helmet issue how are you liking it? I've been in a freeze on the pinball stuff for the holidays but that's likely my next purchase. As Paul said, Herg is great and should help you out. Oddly enough I'd thought the OCD didn't do anything for the helmet so I'm kinda curious what the end solution will be. Good luck!
The difference is subtle. It really depends on the quality of bulbs that you start of with. I was having problems with some of my bulbs flickering or not turning on al all. LED's don't fade very well so games that have lots of fading will notice an improvement. I also installed the boards in my POTC. Prior to installation, the LED's were bright and "sharp" in appearance with some flickering , now they are softer with no flickering noticed and just makes it a more pleasant pinball experience especially in low light rooms. You can adjust the brightness as well. Sterns are much easier to install but WPC89 takes a bit more time. I will keep you posted if I find a resolution for the helmet not turning on but until then you may need to hold off on getting these boards for BOP. If I can't find a solution, I may need to uninstall.
It was also my understanding that those boards didn't do anything with the helmet as it's run separately.
I've also been told that with the LEDOCD you should not run them with ghostbuster lights. I've got it on my IM and it looks great. I wonder if some of you challenges may be with having ghostbuster lights in there too (assuming that is what you have).
Quoted from 85vett:It was also my understanding that those boards didn't do anything with the helmet as it's run separately.
I checked the voltages going to the helmet and it was just below 1V, I rechecked all the connectors to ensure that they were secured properly, I uninstalled the ledOCD and still no helmet lights. I reinstalled the LEDOCD back again and uninstalled the GI OCD and the helmet lights came back up. Therefore, problem is isolated to the GI OCD. For now I will keep the LED OCD installed with the GI OCD uninstalled, at least I get helmet lights, albeit flickering ones
The helmet lights have their own board under the playfield and don't run off the GI, they should work with the GI OCD board in, so that's pretty weird. It's definitely a known problem that they can't be controlled by the boards, it's spelled out on the OCD site and talked about in this thread: https://pinside.com/pinball/forum/topic/bop-helmet-lights-ledgi-ocd-problem
Gonna put in repro playfield make it 2.0 restore this playfield and buy another bop keep it original
I just finished restoring my BoP (new playfield, cabinet refinished and decalled, etc.), and installed/programmed a pinduino. Figured this crowd would appreciate the effects:
Quoted from MustangPaul:You bet we appreciate it. Now make a plug n play kit so we can do our games. GREAT job.
Glad you like it Paul! Did you contact Rock914 about making a PnP kit? Otherwise, this is a walk in the park compared to a PF swap.
No I didn't.
A walk in the park for some but I don't know squat about this kind of stuff. I'm lucky if I can read instillation instructions.
Quoted from lyonsden:I just finished restoring my BoP (new playfield, cabinet refinished and decalled, etc.), and installed/programmed a pinduino. Figured this crowd would appreciate the effects:
I really like what you did there, thanks for showing
+1 and count me in....very nice
Quoted from burningman:+1 and count me in....very nice
Same here... I just want to be able to hide all the LED's so they are not directly seen
Glad you all like it. For the LEDs in the helmet, I'm running the modified version L-8 ROM with ghosting and billionaires patches.
Quoted from lyonsden:Glad you all like it. For the LEDs in the helmet, I'm running the modified version L-8 ROM with ghosting and billionaires patches.
Oh I see.
Quoted from wierdeer:Bubbly Mylar had to go then had to reset raised inserts
Looks great! What method did you use to remove the mylar? Did you have to decal the inserts after? Did you clear the PF after you took off the mylar? I've read some horror stories about doing this to BoP which is why I ask.
Thanks for sharing...
Quoted from wizard_mode:Looks great! What method did you use to remove the mylar? Did you have to decal the inserts after? Did you clear the PF after you took off the mylar? I've read some horror stories about doing this to BoP which is why I ask.
it came up so easy freeze spay and pull only pull on frozen part to avoid paint loss
i was scared to do it but i'm on the list for a new repro playfield. so i decided i would try and see what happens....dont be scared just buy the freeze and remove
Quoted from Mancave:The adventure begins
DSC02012_(resized).JPGDSC02017_(resized).JPGDSC02018_(resized).JPGDSC02019_(resized).JPG
OH man, we'll be following.
Quoted from wierdeer:glue was a pain tho.... blisters on all my fingers when done
How did the dried mylar glue come off the inserts?
Didn't loose decals....gotta do some paint touch up on the inserts that raised,a little sanding in shooter lane, and fix somebody's hack job on a post that was moved because the original hole was stripped out....then im gonna clear it... this playfield will go into the cab that i keep 1.0 since it is original!!
Quoted from MustangPaul:How did the dried mylar glue come off the inserts?
fortunatly for me it was not baked on like the ones you encountered...came off with elbo greese
Quoted from wierdeer:fortunatly for me it was not baked on like the ones you encountered...came off with elbo greese
Man are you lucky. I just don't want to get into mine so it looks like I have a wall hanger.
Quoted from MustangPaul:Man are you lucky. I just don't want to get into mine so it looks like I have a wall hanger.
I've seen yours try putting a little mound of flour in the areas that are caked up then drip 90 or better isopropyl alcohol on the mounds let them soak for a little bit then rub off put fresh flour on your finger from time to time
Quoted from wierdeer:I've seen yours try putting a little mound of flour in the areas that are caked up then drip 90 or better isopropyl alcohol on the mounds let them soak for a little bit then rub off put fresh flour on your finger from time to time
I tried that and it took the decal off and still didn't do that much to the glue. The only thing to do is to pop out all the inserts, sand flat and epoxy back in and that's just for starters.
Don't think I've ever see a rubber ring that size that's on your mini playfield
Maybe chisel off glue and decal while in the game... intentionally raise the inserts with heat gun sand put on decals and reset flat
Quoted from wierdeer:Maybe chisel off glue and decal while in the game... intentionally raise the inserts with heat gun sand put on decals and reset flat
That's not the way it's done, the only way is the proper way.
Quoted from mollyspub:Don't think I've ever see a rubber ring that size that's on your mini playfield
LOL, yeah i know, ordered the wrong size super band one's a while back, it still worked fine with no ball hangups but after the restore it shall be changed
Quoted from MustangPaul:That's not the way it's done, the only way is the proper way.
vid1900
Pinside member
Unknown
4y 45,650 23,495 15
Sharpen a chisel and hold it completely vertical (not at an angle like you normally use a chisel), the old clear and silkscreen will come right off.
Only do this on inserts you want to remove the printing, glue and clear coat from.
Also vid goes on about how to do this post# 863 in his giude
Quoted from wierdeer:vid1900
Pinside member
Unknown
4y 45,650 23,495 15
Well I never saw that one.
I'm no expert.... This is my first playfield restoration. but vid on the other hand is in my opinion is an expert.read the guide front to back I believe it will inspire you to try
Quoted from wierdeer:I'm no expert.... This is my first playfield restoration. but vid on the other hand is in my opinion is an expert.read the guide front to back I believe it will inspire you to try
I've read parts of it but not for a while.
Quoted from wierdeer:it came up so easy freeze spay and pull only pull on frozen part to avoid paint loss
Wow awesome! I am off to trade my BoP this afternoon so I might be exiled from this club for a while! =( But, if my trade falls through, I will definitely be doing this to mine. My PF is nice except for the mylar...
Quoted from wizard_mode:Wow awesome! I am off to trade my BoP this afternoon so I might be exiled from this club for a while! =( But, if my trade falls through, I will definitely be doing this to mine. My PF is nice except for the mylar...
Just removing the janky mylar and adding some LED's increased the value of my BOP an easy 30%+
Dare I say the playfield looks almost as good as new after a few good coats of 100% carnauba wax and the whole machine is now better then new thanks to LED's which allow me to play in the dark and better ball action vs old bubbling mylar.
Get that mylar off people!
Oh MAN....OH MAN....OH MAN....I'm sooooo excited. Just got the email from PPS saying my pf has been shipped. This wait is gonna KILL ME.
I got the email a few days ago too, it was all in German, so for all I know, they could be sending me chocolate, beer, and a poster of Farah Fawcett
Uuuuummmmm does anyone know how these wee things go back together ??
Seriously though, if i can draw peeps attention to the last 2 pics and here's some questions.
A) The wood portions that the cabs sit back on when in storage/transportation mode have completely gone to cheese, no idea why they seem to have water damage (board is flaking apart) cause the rest of the cab is super dooper tight all over, not even any popped seems. The question is has anyone replaced these before? and just how did they do it? or Suggestions??
B) Does anyone else's cab have the pink stickers attached (B19) surely that's not factory applied and if so i doubt it means the cab number?
Discussion and input needed please
Lastly, what's the best way to remove the side rails cause those suckers are stuck on bloody GOOD?
Quoted from Chosen_S:I got the email a few days ago too, it was all in German, so for all I know, they could be sending me chocolate, beer, and a poster of Farah Fawcett
To funny. I bought mine through PPS so mine was in English. Yours was shipped from Germany and mine from the US sooooo I wonder who will get theirs first, you or me.
This page was printed from https://pinside.com/pinball/forum/topic/bop-clubnon-20/page/12 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
