New! Dark mode!
(Topic ID: 185678)
Bop bumpers staying engaged (sort of)
By Spraynard
  • 16 posts
  • 4 Pinsiders participating
  • Latest reply 3 years ago by alexanr1
#1 3 years ago
I have this peculiar problem on my big game. when the bop bumpers fire they stay on--however they don't seem to be locked on at full power. for example, I can bang my fist on the playfield or trigger another pop bumper to fire and the ring will return to normal position. Interestingly, i cannot manually push down the ring and get it to stick, so it seems that it is maybe electric.
I've loaded a video to youtube to illustrate.
Any ideas on trouble shooting?
#2 3 years ago
If you turn off the game while they're down do they come up? If not, it's a mechanical binding problem probably. Do they move freely? New sleeves?
Rarely it could be that the coil stop is magnetizing. Put a bit of thin cardboard or something at the bottom sandwiched between the stop and the coil.
#3 3 years ago
Quoted from zacaj:
good call on turning off. I just did that and they stay down, suggesting it is not electrical. the weird thing is I cannot repeat the behaviour manually-- if I manually push them down they pop right back up.
The other peculiarity is that this occurs on all three pops.
Oh and yes, there is no obvious binding. in fact i just rebuilt all three pops. (new sleeves).
#4 3 years ago
Check the coil stop. It might be mushroomed and/or magnetized extending the stroke and grabbing the plunger.
#5 3 years ago
Quoted from Spraynard:
I had the magnetizing problem on all six bumpers of my Black Hole. Not sure what the cause is, maybe just a bad batch or something
#6 3 years ago
Quoted from zacaj:
is there a way to demagnetize or do you have to just buy new ones?
#7 3 years ago
Coil Stops should be replaced. I will leave it up to someone else to get you the proper part number from a manual. It might be a screw in stop or plate with mounted stop, but are usually not expensive at all and a easy swap. They are a regular maintenance part like brakes on a car and will last you a life time in home use.
#8 3 years ago
I have also seen really dirty coil sleeves, rusted bumper arms and springs that need replaced. All mechanical issues. I would recommend tearing them down and going through them checking all of this and possibly magnetic issues.
#9 3 years ago
Quoted from Taxman:
Most of them aren't replacable though? Sterns might be the exception actually, depending on the year....
No way that I know of. Try the cardboard to see if it fixes it
#10 3 years ago
Quoted from alexanr1:
Yes, they were just disassembled and cleaned. The only thing I didn't replace was the coil stops.
#11 3 years ago
Quoted from zacaj:
when you realized your coil stops were magnetized, would the plungers stay down when you manually depressed them? the thing that has me most confused is that when i manually move the plungers, there is no binding or sticking or anything. they only sticks when the coils are energized.
#12 3 years ago
Nope, only when they fire. The coil would magnetize them just enough to hold the plunger down, and it'd fade eventually.
#13 3 years ago
Could you overcome the minor magnetic issue with a stronger spring? The coil energized is very strong and will compress a stronger spring. Just a thought...
#14 3 years ago
Did you ever resolve this?
#15 3 years ago
oops forgot to update! So here's what I did....
Took out the plunger and coil stop. ran the plunger through a demagnetizer a few times. Then dropped both onto concrete a few times from about waist height. Then I stretched out the springs a bit more to make them stronger.
After I put everything back together, everything seems to be okay. There is one pop bumper that sticks sometimes, but for the most part, all good. Since I shotgunned it I have no idea which of those things did anything meaningful, but all that matters is it worked.
#16 3 years ago
Glad you resolved it.
$ 149.95
Allteksystems
$ 119.95
Allteksystems
$ 6.00
Siegecraft Electronics
Third Coast Pinball
$ 49.99
PinballElectronics.com
$ 149.00
$ 7.00
$ 12.00
Third Coast Pinball
$ 9.00
Cabinet Parts
Third Coast Pinball
