I'm really not sure where to post this one, so I apologize if it should be somewhere else.
I bought a non-working Booz barometer. As soon as I opened it up, the problem was evident. There are two small coils wired together that pull down a 'tang' to ring a bell. One is a nice pretty copper color, the other is black and the wire going from one to the other was charred to the point of disintegration. This is a 6 volt system (originally running from a battery). If someone knows a source to get a replacement bell assembly, that would be great since the bell assembly is put together with bent tabs and rivets making extraction of the coil a challenge. If not, plan B is trying to replace the one coil. So, any idea how to identify the coil or a suitable replacement? There is no wrapper and it is very small (about 5/8" tall and 5/8" in diameter).
Advice?
