My Boomerang game has played well up until now. Tonight I turned it on to play a game. It is set for free play. Does not seem to be a tilt condition. Game would reset and then immediately turn off without launching first ball. Apparently the ball just sitting in the bottom of the apron on the ball actuator would make the game go out. I put the ball in the shooter lane and tried again. The game then would stay on. I pressed some slingshots and some targets, scoring ok etc., but as soon as I touch a rollover button or a rollover lane wire the game turns off and now will blow the 50 volt fuse after an attempt or two.
The game was last played about a week ago and went to play it tonight and I have run into this trouble.
Additional : edit.. I noticed a bright arc at the "outhole" relay in the cabinet when I push the start button. I cleaned the switch points at the arc. No change. I slipped a piece of paper in between those points and then the ball would actually launch when I pushed the start switch however as soon as you go over roll over button or wires on the playfield the game goes out. I also noticed at least on of the targets up in the area of the upper circle with the pop bumper will cause the game to go out. Slingshots and lower abcd targets cause no trouble and will score. Game resets fine.
Any idea what might be causing the issue ?
