so when you step up do you stop at the upper limit switch, ie hit the missing tooth? It looks like you will...
Quoted from pinhead52:so when you step up do you stop at the upper limit switch, ie hit the missing tooth? It looks like you will..
Yes, the steel pin on the left side of the wheel hits the top switch and the missing tooth stops it from going any further. It is not counting down. I noticed that the Bonus Zero relay is pulled in and stays pulled in, should this be happening? Also noticed the shoot again light is lit. I will check into the shoot again light.
Of course you can manually count it down... You'll want to make sure the zero switch is closed with any bonus registered to ensure the game knows to count down. Im not familiar enough without looking at diagram to know where to look.
Pinhead52
Quoted from pinhead52:You'll want to make sure the zero switch is closed with any bonus registered to ensure the game knows to count down.
Is the zero switch you are talking about located on the bonus unit?
This page was printed from https://pinside.com/pinball/forum/topic/bonus-unit-rebuild and we tried optimising it for printing. Some page elements may have been deliberately hidden.
