Hi ... Trying to get my buddy's Bone Busters working all the way ... The pop bumper and the ball shooter (way down in lower left of PF) do not work ... Switches seem good ... Coils test good and fire when given current (diodes on coils tested good)... I tested most of components on the mini boards that control these and the little boards seem good .... He got game with a Swemmer MPU, NiWumpf Driver Board and NVRAM Power Supply Switcher board.
During Self Test (Self Relay and Solenoid Test) > the Pop Bumper and the Ball Shooter (in lower left) never fire .....
UPDATE >> I noticed in Owner's Manual it says "L12 enables ball shooter" > so LAMP 12 ?? No lamp 12 listed (see photos) ... WHERE IS LAMP 12 ?? and does this mean if lamp 12 is burned out (or socket is bad) that the shooter won't fire ??? (or bad component on lamp driver board)?? BTW >> One of the red light tubes is not working ... and LED's were installed in the head (behind the translight)
ALSO > see the Ball Shooter is dependent on the state of the "S" Relay ? Top Left Flipper works (so does the skull topper ... skull turn and jaw moves ... Not sure if it lights up) .... Since top left flipper works >> then the "S" RELAY IS NOT THE PROBLEM ??
AND > The pop bumper coil and left shooter coil have diodes across the lugs ... ARE THEY BOTH SUPPOSE TO have a diode on coil ?? This game has a couple small Diode Boards under the playfield .... I don't want to remove the diodes and fry something (but if diode on coil is an "extra" diode would that stop solenoid from firing??) ...
Any help would be greatly appreciated !!! Thank You !
