Counter argument for what's included in this Pro:
What has passed for a "basic" Pro BoM in the past is 2 flippers, 2 ramps, typically a main toy (interactive), often a secondary toy (static)... then a few from the grab bag of drops, spinners, up posts, captive balls, scoops/saucers, powered gates, and magnets. This is more or less the case for SW, GOTG, DP, BKSoR, STH, Munsters, AS, Kiss, ACDC, IM, Mustang, TAV, TF, Avatar, and GoT.
Somewhere in between are the games w/ 2-3 flippers, 2-3 ramps and some other goodies to make a very solid Pro - ST, GB, TWD, GZ, LZ.
The more "fully featured" Pro's as of late share a lot in common. Some Pros get more in them: 3-4 flippers, 2-3 ramps, the main interactive toy + more static toys to fill up the empty space, and even more from the aforementioned "grab bag". This would be the case for AIQ, TMNT, MET, XM, Rush, IMDN, Mando, JP, and IMDN. Focusing on Pro BoM only, this group is very appealing at the Pro level because it looks fully featured and not empty.
Having said that, I'd argue that Bond Pro is in the "fully featured Pro" group. 3 flippers, 2-3 ramps (semantics due to the split entry ramp), Main Interactive Toy (Bird One Rocket) w/ a static building behind it, A SECOND INTERACTIVE TOY (DB5), an upwards scoop from an under flipper shot, a 3-bank of drops, an up post, and a spinner.
What makes it look "barren" to some is probably that the ramps are either low or close. Ramps don't touch or go through the backpanel, so there's some empty space back there. Similar to how DP and BM66 sort of look empty in the way back (also Gomez games). But I'd argue this has more to it than the commonly adored GZ Pro, and much more than other popular Pros like GoT, Kiss, or SW.
Obviously code execution and theme integration can move the popularity of all these up and down (DP goes up in value, TMNT leaves something to be desired)... and with Lonnie rumored as the main programmer, we can certainly hope to be pleasantly surprised to avoid saying the obvious. But as far as features are concerned, Bond Pro is up there with the best for BoM on a Pro level title.
Edit: Also, what Bond Pro lacks over the Prem (jetpack, dragon tank, underwater scene, Bird One physical lock) can be cut in half easily w/ cheap mods. The underwater scene looks like it can be easily modded for the Pro, same with the dragon tank. Both look like short money mods too. So you can have that hated word "Promium" pretty easily and only be out the jetpack and Bird One lock.
