EDIT: 11/7/14: Found a solder joint on the back of the driver board that had the J1-2 and J1-3 touching, I re-soldered them and the game appears to work as intended!
EDIT:10/29/14: Issue below was a fuse, game boots with the last driver board that was used, center pop bumper does not fire.
EDIT 10/28/14: Game no longer boots since putting in different driver board after it had booted and played once before.
EDIT: Found that when the chime 10 coil fires so does the down post coil.
Hey guys, having some issues with a Power Play, any advice is greatly appreciated.
1. game tells me that switch 25 (post down rollovers x2) are closed, while they are not physically closed, they do not respond in anyway when pressed.
2. Up Post acts funny, it raises as intended, however it drops when the ball goes into the saucer or a target bank is completed, the light at the post stays on however. Its only supposed to go down when the ball goes through the return lanes, rolls over one of the two rollovers, or when a new ball starts.
