(Topic ID: 195467)
Bobby Orr: No sound when ball goes over stars
By ericlevin
1 year ago
  • 8 posts
  • 4 Pinsiders participating
  • Latest reply 1 year ago by Billc479
#1 1 year ago
I just picked up a Bobby Orr Power Play. Overall the game is in decent shape. A couple questions (I'm a noob).
When the ball rolls over the stars in the upper alley, whether the stars are lit or not, there is no sound emitted. I don't think this is right.
Any ideas?
Bobby Orr's Power Play
#2 1 year ago
Does the machine score points when you run your fingers over the star rollovers?
#3 1 year ago
I have to press with a bit of authority on the stars for them to trigger points. Rolling the ball over them rarely gets them to score.
When I press with my fingers and I see the points increment, still no sound.
#4 1 year ago
Run a solenoid test and make sure each chime is firing. Next is run a switch test and press each star and see if they register. If you have a manual, it will walk you through the steps.
#5 1 year ago
Do you know how to place the machine into self-test mode? Perhaps the solenoid that triggers the sound chime is bad. Perhaps a wire is disconnected from the solenoid. Or, it could be the transistor on the solenoid driver board that controls the chime solenoid. Lastly, it could be a connector issue on the solenoid driver board.
#6 1 year ago
thanks vdojaq and BallyPinWiz! I just downloaded a copy of the manual. I'll run through those steps and circle back tomorrow!
#7 1 year ago
So...Solenoid test revealed solenoid 7 is bad (there was no sound during this part of the test). The manual says this is "chime 1000". So I think I have my answer as to why sound does not emit when the ball rolls over the stars.
Now I just have to figure out how to repair / replace the solenoid.
#8 1 year ago
After testing your driver board for the solenoid, ( I doubt it's the coil, but check the coil's resistance) check to make sure the plunger is not stuck to the rubber stop on the bottom of the frame. I had a Bally that was "barn stored" and the plungers were stuck. While you're at it, get a chime unit rebuild kit from PBR and rebuild it - the sound will be much better. (If you haven't already done so).
$ 7.65
Cabinet Parts
Third Coast Pinball
Third Coast Pinball
Third Coast Pinball
Third Coast Pinball
Third Coast Pinball
1,500
Brick, NJ
Displays
PinballSolutions.eu
