Hey everybody...
I sent my Pinbot CPU and power boards out for repair, as the game was failing to boot up - turn it on and it would light up, ding, run through the solenoids like normal, but then would restart and just keep doing that. Seemed like board repair was the answer.
So the boards are coming back to me tomorrow, but with the warning that:
"The transistor that controls the general illumination lighting on the CPU board (Q8 and associated components) was literally blown in half. This playfield area should be checked for problems prior to reinstalling the CPU as damage to the circuit may occur again."
I asked for clarification, and was told:
"You need the manual to check the wiring and components associated with Q8 (general illumination switching circuit) under the playfield for shorts prior to reinstalling the board as the board may be damaged as a result (which would void the repair warranty). The manual has all the info within."
I don't doubt this is true, but this is still pretty vague to my unaccustomed to electronic repair ears. Does this mean I need to check every GI bulb on the play field until I find a short? There was never any problem with the play field lighting before I sent the boards out - the problem I was having seems entirely unrelated - but clearly something was up.
Anybody out there ever have a similar problem? I want to play my PinBot again, but don't want to be stupid about this.
