(Topic ID: 273426)
Board Repair : Mattel Las Vegas Pinball
By wiggy07
2 years ago
  • 33 posts
  • 9 Pinsiders participating
  • Latest reply 2 years ago by pincity
#1 2 years ago
Reaching out to anyone who does board repair. My friend has a Mattel Las Vegas pinball that needs board and chip testing as well as replacement of some burned out chips. If anyone is interested and wants to help out my friend it would be greatly appreciated. I know the game is probably not worth much but it means a lot to him since it is a family hand me down. I can provide pics of the board if needed. Of course payment would be provided for the labor and chips. Thanks for the help
Lee
IPDB Entry : https://www.ipdb.org/machine.cgi?id=3820
Video of the pinball machine on YouTube:
IMG_3094 (resized).jpgIMG_3094 (resized).jpgIMG_3101 (resized).jpgIMG_3101 (resized).jpg
#2 2 years ago
I see some spider chips on the board.
Full sized schematic of the board is here:
https://www.pinwiki.com/wiki/images/8/85/LasVegas_schematic.pdf
Service manual is here:
https://www.pinwiki.com/wiki/images/7/7e/LasVegas_Service_Manual.pdf
#3 2 years ago
Quoted from KenLayton:
Thanks Ken for the info, much appreciated, IPDB has the schematics and manual as well. I took a look at both. I was wondering if anyone online fixed or wanted to fix the board since I am not so proficient in board repair.
Thanks again for reaching out.
#4 2 years ago
Maybe try Steve Kulpa?
#5 2 years ago
The display driver spider chip is probably the same as used in Gottlieb System 1 games, but the PPS4 CPU chip is mask programmed and unique to this game.
Most probably, and least costly, the electrolytic capacitors on board have failed. If replacing those does not help, the switch matrix driver chips are cheap to replace. But more detailed description of the problems would be nice.
#6 2 years ago
There are a few resistors that look cooked as well.
#7 2 years ago
Thanks everyone for the posts so far.
What happened i believe is my friend was replacing the bulbs with the power on and shorted out the game, The game turns on, the lights and some of the switches don't seem to work. Another weird thing is that the scoreboard will turn on but you can see it fading as the power stays on in the game. Just looking for someone to test the chips on the board and make sure they are working. The chips that are cooked and failing would need to be replaced.
Treborlicec, you are correct the 2nd pic shows some resistors that blew on the board. It seems like no fuses are used in the game so the resistor takes the hit when the game is shorted out I assume.
Ken, thanks for the lead, maybe I will give a shout out to Steve and see if he is willing to look at the board.
Thanks again for the responses.
#8 2 years ago
Maybe reach out to the guy in the video you posted from Pinball Mayhem. It sounded like he was going to be working on fixing the board on the one he purchased.
Ed
#9 2 years ago
Quoted from eharan:
Ed
Ed, good idea, i just reached out to Pinball Mayhem. Thanks for the response to the issue that I posted.
#10 2 years ago
Quoted from wiggy07:
Jeremy from Pinball Mayhem here
It may be a month or more before I really dig into mine but I have made some good progress with some basic testing. Turns out the board won't fully boot when a switch is stuck (makes sense). I disconnected the playfield switch harness connector and shazam - it booted. So my board appears to be properly working but I have not fully tested it with the playfield switches plugged in.
I will shoot you an email
Jeremy - Pinball Mayhem
#11 2 years ago
Here's some information for board repair people:
It appears the transistors which are "house marked" as 224N1 are actually 2N3904 and the ones marked 223P1 are actually 2N3906.
#12 2 years ago
Thank you
#13 2 years ago
awesome, thanks Ken.
#14 2 years ago
Unless there is something wrong with the spider chips, this board should be a fairly straightforward one to repair.
#15 2 years ago
That's what I'll be counting on
#16 2 years ago
is steve still around? I know he used to live near me
1 month later
#17 2 years ago
There are some forum members here that do board repairs.
#18 2 years ago
Here's some pics from the board repairs. Main failure point appears to be that high voltage (30V) got into the switch low voltage (15 volt) and blew a chip. Still working through some bugs but making progress.
Comparison of my board and the board to be repaired. My board is an older version but it appears to only have a few relocated components (minor changes).
Blown chip
here's the underside
left skid marks on the board
new chip sitting in a nice socket
#19 2 years ago
Other repairs and upgrades done to the board (My board will get these also)
This board had high heat marks left by the old zener diode and resistor - new ones installed up off the board for better cooling (small transistor also replaced)
New small electrolytic caps installed
New resistors installed up off the header boards for better cooling (old ones left burn marks)
before shot of old diode bridges
upgraded to 8 amp bridges
#20 2 years ago
That's more like it.
It's good that you are mounting the heat generating parts higher off the board for better air flow. Also good that you use sockets for the integrated circuits.
Good job spotting that blown chip.
#21 2 years ago
Thank you
#22 2 years ago
Nice job Jeremy...
#23 2 years ago
Nice job Jeremy...
Much appreciated
#24 2 years ago
I forgot the most important pic of the board repair - the underside! Where my work really shows - as in it doesn't stick out like a sore thumb where I replaced the chip with a socket.
#25 2 years ago
UPDATE - the bugs have been fixed - apart from some further play testing to verify the repairs stick and nothing else craps out - I am calling this repair done!
So - what were the bugs? Well after the initial component replacement (blown chip, and other components that showed overheating) a game could only be started if a pop pumper or sling was activated first (very odd). On this game the solenoids are active all the time (there is no relay for these). Also during a game the pops/slings would not score any points.
There was more than one reason as is the case with most things that are 42 years old. ONE: a simple resistance test of the start button circuit path led me to the header pins on the board. Not only were they lightly corroded but when I went to resolder them the solder actually went away from the pins! After cleaning and resoldering the resistance test passed. TWO: As to the pops/slings: This circuit ties the activation switches to a signal amplifier - this signal goes to a transistor and that signal then goes along a similar path as the start signal. I believe this transistor was flaky and locked on causing the start signal to be ignored. After a pop was fired the transistor would relax. I tested this by removing the transistor - the game would start normally. Lucky for me this was the same part number transistor that I replaced in the high voltage circuit and I ordered extras (always order extras if they are cheap).
In the pic below my son is enjoying testing out the repairs
2 months later
#26 2 years ago
Had a problem happen on my board with the sound - thought it might have been the speaker or volume switch BUT it was something different.
#27 2 years ago
Thank goodness the schematic calls out the real part numbers instead of "house" numbers. A nice upgrade to the sound would be to replace that silly volume switch and it's associated three 1.8k resistors with a normal 5K potentiometer to control the volume.
4 weeks later
#28 2 years ago
Quoted from PM_Jeremy:
Jeremy, glad you were able to fix the sound issue. Nice job..
#29 2 years ago
Thank you. I'm building XP with each repair
4 months later
#30 2 years ago
I am working on one of these machines for a co-worker. I have repaired several things but it would not start the scoring. It would start the game but wouldn’t start registering points.
I was testing the circuit from the rollover switch to start the scoring to pin 31 of IC1 and didn’t seem to make contact. I was inspecting the legs on IC1 and it looks like someone tried to re-seat the chip and bent some legs. I pulled it and was trying to straighten the legs. Two broke off
I’m going to try and tack some back on.
Is there anywhere to get these chips?
#31 2 years ago
Hmm that is a major setback for sure. A used board is my best guess for a replacement chip. But this chip may be salvageable. If you carefully remove part of the plastic over the broken pin you should be able to solder a thin wire onto what's left of the broken pin.
#32 2 years ago
I guess I’m in the market for a board now. I’m hoping I can tack some legs back on, but not sure.
Someone really made my life harder folding these legs. I didn’t want to pull it out, but it had to be done. If I can find another board I will just desolder the whole chip and socket together.
#33 2 years ago
Quoted from pincade:
I haven’t worked on this exact chip but I’ve done this before on other ones. I was able to tack a new leg on a few chips by extracting a leg from a spare twin leaf socket. I just cut off the leaf portion and cut down the socket leg to size, tinned it, was able to tack it on the chip leg.
If you have trouble lining things up, you may be able to put the chip back into the socket with the broken legs, carefully insert the new legs into the appropriate positions, and the socket should hold things together while you tack it. Just be careful not to melt the socket lol.
This page was printed from https://pinside.com/pinball/forum/topic/board-repair-mattel-las-vegas-pinball and we tried optimising it for printing. Some page elements may have been deliberately hidden.
