(Topic ID: 199393)
Board blown up - Photos needed - Bally Truck Stop
By ilikepinball
  • 8 posts
  • 2 Pinsiders participating
  • Latest reply 4 years ago by ilikepinball
#1 4 years ago
Hi, I had to remove the head, disconnect all cables and put it together again.
I guess I just blew my board ...with a "pop" and "buzz" sound. Looks like its was "C1" and "C3", whatever its for.
I named the plugs but there must be obviously a error.
Could somebody please send me photos from the head?
I mean from all plugs inside the head and plugged ones on board?
Thank you so much.
#2 4 years ago
Those two tantalum caps always blow on that board. Replace them with electrolytic caps 10uF 25v+
The tantalum cap failure could be from excessive ripple on the 12v supply. You can check VAC across the 12v filter cap on the power supply board. Anything more than quarter volt of AC seen and that cap needs to be replaced.
#3 4 years ago
I didn't know that. Thank you. I will check and change the caps.
To be sure that I didn't had a black out while playing with the plugs, I still need photos.
Anyone out there with a Truck Stop?
#4 4 years ago
Quoted from ilikepinball:
I suppose if the 12v was hooked up to the 43v it would make those caps blow too. I think they are rated 25v.... but it is very typical for those caps to be bad.
The bally manuals should help. Even if you dont have one for truck stop, a similar game will be wired up the same. The way the connectors are done, you have to try pretty hard to plug something in wrong.
Often on games that have sat for a while and then powered up, both of them will go off like firecrackers. Usually those boards looks like this.... evidence of a burn out
#5 4 years ago
... oh boy ... thank you for help!
I disconnect the the power supply board
.... and guess what... I buzzed again. Pretty strange without power
Now the transistor Q5 was blown up.
You are right, normally its hard to get the plugs wrong connected, but this two plugs fits well between themselves:
Thats the bill, for working in a dark garage and didn't double check the wire colors
Now the lights on playfield are burnig an the displays are showing two letters, no LED on board blinking, no attract mode. Seems the board is dead. I'm new into pinball electronics, but I figured out to check some components.
I done some measurements in the area above, shown on the photo:
D7 Glas-Diode shorted
Q5 Transistor shorted
R14 Resistor should be 82K OHM but its 33K
R15 Resistor should be 62K OHM but its 5,2K
R11 Resistor should be 47K OHM but its 31K
What will be the result, when a resistor does not have the right OHM-value? Does the board will still work somehow?
Anyway, what do you think. Its the board ruined, or should I try to change the components?
I need a beer
#6 4 years ago
reset is generated by 12v. Since parts there went bang, including tantalums what are probably across the 12v too, id imagine you hit the 12v supply with over voltage.
I don't think it is ruined, but it will probably take some work to fix. I would replace what has failed and see where you are. The resistors are probably fine, lift one leg and recheck if you want to be sure.
#7 4 years ago
Thank you. I ordered the parts. I will come back. I may need your knowledge
1 month later
#8 4 years ago
Hi, i'm back again. I spend hours to try, test and learn. But in the end, I get no sign of life. I orded a new CPU, Game-ROM, Test-Rom, RAM PIA and PNP/NPN [...].
I used the pinball 6803 repair guide from pinrepair (Clay Harrell).
I tryed to get the test-rom running, but the board is still dead.
I checked/changed:
C1: 6.8 mfd (non-polarized)
Q2,Q6,Q4: 2n3984
Q3,Q5: 2n4403
D1: 1n958b (7.5 volts, 1/2 watt)
D3: 1n4148 or 1n914
D4,D5: 1n4606 (can substitute 1n4148 or 1n914)
So I took a closer look at the CPU:
There are U1 CPU chip (renewed) at pins 4,5 +5 volts. But pin 6 is only 2,82V (always) - power on = 2,82V...no up no down.
"Reset is fed from +12 volts through transistor Q2 and Q3" = there are no 12V....
Q2 = 0,71V/1,41V/0,70V (renewed) - measurements on legs
Q3 = 4,43V/3,82V/4,54V (renewed) - measurements on legs
"When capacitor C1 (6.8 mfd) is charged at boot up, this will launch Q4 (2n3984) and which opens Q5 (2n4483), thus bringing +5 volts to U1 pin 6 as the reset."
C1 gets only 2,81V and on the other end on C1 we have 0,73V (C1 renewed two times, same results)... guess that not enough to charge the capacitor?
On TP2 we have 4,54V (power supply direct connected the DMM we have 5,1V) and on TP3 12V
I tryed to read the electronic schematic, but its confusing for me. It all starts with 12V on D1 and we have 12V, then trough D1 we have 4,98V on the other side. R1 - starts with 12,10V and ends with 12,08V [...]
Any idea how to figure out, why the cpu dont want to work?
Help needed. Thanks.
