I recently purchased my first pinball machine, a 1976 Williams Blue Chip in great shape (thanks Jay!). The machine is nice and everything was working fine when first purchased. The game plays well, but I have an issue which is more of an annoyance than anything, and I want to figure out what is going on. The issue I am having is that after the balls are played out, the "game over" light does not light. I checked the obvious items first - confirming that the bulb is working (which it is), and then proceeded to check for 6V AC at the lamp's base when the game is over, which is not present. So, next I checked continuity on the wires back from the "game over" relay switch (labelled as O/W and Y on the schematic), and those check out. The game is on free play without match, but since the match unit is on a leg of the circuit from the game over relay, I turned it on to check if it would engage when the game was over. The match unit did not engage, and a bit of checking with some jumper wires confirmed that I need to order a Flexstone file for the contacts on the leaf switches for that unit (which is shared on the game over relay, albeit on a separate switch). I checked the voltage path from yellow (which is the "hot" wire throughout the game) and the blue wire on that game over relay, and I have a steady 6V AC across it. I even engaged the tilt light and then energized the lamp just to confirm that it works if given power (which it does). I'm wondering what I'm missing here. The schematic looks to be fairly straightforward, involving the blue and yellow leads to the game over relay in a normally closed configuration (when the game is not being played, that is). Any ideas on next steps to troubleshoot this? Everything else on the game works great, and it would be nice to have this feature work as it should. Thank you in advance for any help you can provide!
