If you pulled one wire of a lug of the coil to test this and it came up 2.5 then the coil is bad for sure. replace.
To backtrack a little I test all my coils (except flipper) with my digital multimeter first leaving all wires on because it is fast. Then if get a coil that tests under 4 ohms I unsolder one of the wires of a lug and test again as you can get a false reading with wires on. If it tests under 4 ohms it is suspect and I replace as a weak coil is the same as a bad coil. 2.5 or under bad for sure.
I bought my schematics and manual from PBR so you might want to check again as you may have requested original documentation and they only have copies.
Also I did not want to burden you with a fuse alternative so soon, but others have mentioned it, as down the line you could buy an in-line breaker from Mouser.com. part #655-W57-XB7A4A10-5 Tyco 5 amp breaker for around $2.00. You would need to modify it a bit and Just need put a blown fuse between the the two lugs. It will save you a lot on fuses. I have not bought one yet myself and have shopped a lot of EM machines but have not had an extensive electrical problem as you have.
Ken
