(Topic ID: 118593)
Blowing 24v 15A fuse on 68 Williams Cabaret
By fotoboy
9 years ago
#1 9 years ago
Hi EM'ers...
I have a 68 Williams Cabaret that I am restoring. I had everything running satisfactorily, ye-haw. Then I removed PF and did the super duper new rubber, clean/wax plastics and PF. Now, before anything happens, I blow the 24v 15A fuse. When I first put the PF back and started up, I got a reset except for one score reel in player 1, which would buzz and not move. I have checked and/or adjusted switches on all of the reels. After a couple adjustments, it just started blowing fuses when I press the start button. It seems that there are a bazillion possible ways this could be happening, any advice would be helpful. I also have schematics if anybody needs me to post them.
Thanks [sigh]
#2 9 years ago
Dear fotoboy
I bought an Cabaret too - also for "to restore" ... Your 15 Amp-24VAC fuse blows. Question: How long was that "Coil in Player-1-Score-Reels" buzzing and "not moving" ? Such coils can stand 30 seconds of "constant 24VAC power" - maybe up to 1 minute (maybe up to 2 minutes). Has the coil gotten VERY hot -> insulation of the thin wire melted / burnt -> THERE is Your electrical short ?
Do You want to unsolder the wire on one side of the coil - and then try again to "start up" ?
Has a piece of wire or a screwdriver or such been fallen into the cabinet making a short ?
I also have a Shangri-La: http://www.ipdb.org/machine.cgi?id=2110 I have an idea "to track down" for the "relay having a short". In ipdb-shangri-La-Manual: On the first page we see the transformer and the fuse and after that, the wire runs to the "Right" - all the way through the machine / schema. All relays have one side of its / theirs / the coils connected to that wire. It is the connection to "transformer-phase-POWER".
On page-4 I see a Normally-Closed-Switch on Game-Over-Relay. And then a Normally-Closed-Switch on the RESET-RELAY. If I would put an insulating piece of paper into this switch - the switch on the reset-relay is OPEN (all the time): THEN I turn on the machine -> IF THE FUSE BLOWS: The relay (with the short) is on the LEFT side of that switch. IF THE FUSE DOES NOT BLOW: The relay (I am looking for, the one with the short) is on the RIGHT side of that switch.
On Page-5 of the schema I see an Normally-Closed switch on the Tilt-Relay: Same procedure ...
Want to try ?
I am interested in a copy of your schema - can You post it ? I bet, ipdb.org would also like to get a copy -> "to donate" is simple: Here (Cabaret): http://www.ipdb.org/machine.cgi?id=415 -> to the Right -> click on the button "Submit Changes" and donate - someplace you should write down your real-EMail-address (just, if they have a question - they won't). It will take weeks until they show that / Your schema. ALL "cabaret-Owners" will like You. Greetings from Switzer-Winter-Land Rolf
This page was printed from https://pinside.com/pinball/forum/topic/blowing-24v-15a-fuse-on-68-williams-cabaret and we tried optimising it for printing. Some page elements may have been deliberately hidden.
