I’ve got a Black Hole that every now and then “freezes up”. It has never happened during a game in 3-4 years, but only during attract mode. However, it happens infrequently enough that I would say I’ve just been lucky in that regard.
When it freezes, the controlled lamps will stop cycling for attract mode, and one or two of the displays will usually be displaying a single digit that appears to be very bright. The side gate stops cycling, but the infinity lights still rotate. There is no more sound going on.
I’ve done all the ground mods on the unit, replaced the orange electrolytic cap, completely rebuilt the CPU board in the battery area, as there was a fair amount of corrosion. That went well, and the board fired up right away afterwards.
I’ve suspected that I might have some instability on my 5V supply, so I’ve monitored it with a scope, set to capture if the 5V dips below 4.7V. I’ve had lockups and no captures, so I don’t think that’s the problem. I’ve also use the trim pot on the power board to turn the 5V up to 5.2, to give a bit more of a cushion, but it still locks up.
Does anyone have any suggestions on what to look for next? I’ve got the tools available to get this done, but I just kind of feel like I’m hitting a wall. Any extra guidance of what I should look for next would be greatly appreciated.
Thanks,
Jeff
