(Topic ID: 147844)
Blitz Wax Question
By Glarrownage
5 years ago
  • 17 posts
  • 13 Pinsiders participating
  • Latest reply 5 years ago by Lermods
    #1 5 years ago
    Sorry to add to the extensive list of wax topics (which I feel like I've read most of in search of the answer), but I just switched to Blitz and had a question. I know Blitz is fairly hard but mine is almost completely crumbled and does not spread well at all. I was wondering if this is normal and if not is there anything I can do to my current jar (like heating it or something) so that it makes less of a mess on my playfield? Sorry for any misspellings I'm on my phone.
    #2 5 years ago
    Put it somewhere warm (like a window or heat vent).
    #3 5 years ago
    Quoted from vid1900:
    Thanks Vid, will do! The first thing I tried was using my heat gun on a small portion I was about to apply to the playfield but it hardened to mostly the same crumbly mess. I assume that maybe the longer slower heat you recommend may reform the consistency of the whole container? I guess I should also ask how much crumbling and chunks of wax should I expect to clean off the playfield? Should it mostly spread evenly across the play field or is this chunky mess pretty common with harder waxes?
    #4 5 years ago
    It is hard but no crumbles on mine.
    #5 5 years ago
    You must have gotten a bad batch, mine doesn't crumble send it back.
    #6 5 years ago
    I hated Blitz personally. I thought it was difficult to use and messy as shit.
    I've used this now for about two to three years and love it. It's easy to use and the ball screams across the playfield. I'm certainly not a wax expert, but other Pinsiders have had great success too.
    #7 5 years ago
    If you use the right applicator, you'll find that it'll "melt" with friction when applying. If it's truly dry, then you probably did get a bad batch. It should feel wet and oily to the touch.
    #8 5 years ago
    Quoted from VolunteerPin:
    Quoted from Pizza-Bob:
    I figured it should be a lot smoother, thanks for confirming! The top half of the can was completely crumbled and the bottom half was as everyone else describes. I attempted unsuccessfully to remove all the dried and crumbled pieces from the good stuff. My next move is to try to melt all of it together. Regardless, I'll be ordering a new container.
    Quoted from Toasterdog:
    Thanks for the recommendation! I'll order a can for sure. Do you think you may have had a bad batch of Blitz when you tried it?
    Quoted from tamoore:
    Half of it does feel oily and moist, the other half is really dry. I was using a microfiber towel as the applicator. Even when pressing one of the crumbled pieces into the playfield to smooth it out it breaks off into smaller pieces and just makes a total mess.
    #9 5 years ago
    You have a bad batch . I love blitz wax , it sucks that you didn't have a good experience with it because it is like butter. Send it back and reorder
    #10 5 years ago
    Thanks bob, yeah a lot of people on Pinside swear by it. Good to know this isn't the way its supposed to be or waxing the playfield would turn out to be quiet the endeavor. I'll give it another go.
    #11 5 years ago
    41 bucks for wax? Why? What makes this stuff better than mothers?
    #12 5 years ago
    The wax could of been frozen or got very cold. Or the other, extreme heat, evaporated a solvent out of the wax. Either in transit or on a shelf some were. Unless One Grand (Blitz) only makes small batches of 5 gallons at a time, a bad batch is unlikely, since One Grand has been making waxes since 1933.
    #13 5 years ago
    Quoted from dung:
    #14 5 years ago
    Quoted from Glarrownage:
    these work better for application:
    amazon.com link »
    I would rub the applicator in circles in the wax to get it warmed up and lathered on the applicator, then apply to the playfield. I have used blitz for the past year and never has made a huge mess. When it's dry, use your microfiber cloth to wipe up.
    #16 5 years ago
    I haven't tried blitz or fleetwax yet. I have many different kinds (P21s, Mothers, 3M, Turtle Wax, Kit, Zymol, Surf City Garage, etc). My favorites so far are P21s and Meguiars Gold Class. I get Gold Class at Walmart for 10.76, and I think it is one of the best.
    #17 5 years ago
    +1 on P21s. Stuff is great, lasts forever as a little goes a long way.
