Slow down here. don't go removing any chips just yet.
First thing to do is to check the voltage at the 5101 RAM with the game off. at pin22 you should see about 4 volts. If you don't, then the problem is most likely your battery pack or the blocking diode on the CPU board. You'll never get out of audits if you don't have 4 volts at the 5101 RAM pin 22.
Also make sure the coin door is *open* upon reboot. if you have the coin door closed, the coin door switch won't allow the memory to reset itself, and you'll never get out of audits.
Now with the coin door open, do a "quick switch" on the power. That is, coin door open. Game off. Power on the game (and into audit mode.) Now quickly, and i mean as quick as you can do it, turn the game's power switch off and back on. Does the game go to attract mode? if so, your 5101 RAM chip is fine, and the problem is related to the CPU board blocking diode or your battery pack itself.
