Since owning my Blackout, all the lights in Column 7 (on the lamp matrix) haven't worked. This corresponds with Driver Board 2J5, pin 1. Using a paperclip and alligator clips, I was able to determine that it is not the wiring since when I connected to a different pin on 2J5 all the lights work! I removed the board and checked for continuity at the pin at 2J5-1 (which was fine) and just to be safe, reflowed solder there, but no change. Any suggestions on what to check/do next? Seems like the pin at 2J5-1 on the driver board isn't getting power, but I don't know why. Thanks.
