(Topic ID: 233791)
Blackout GI Relay
By StratDoc
5 years ago
  • 4 posts
  • 2 Pinsiders participating
  • Latest reply 5 years ago by StratDoc
    #1 5 years ago
    The diode on the GI relay was bad so I replaced it but installed the diode backwards - big idiot move. Played a game and hit blackout and there was a pop from the backbox and no GI flash sequence. Checked the diode I replaced and it was bad. Installed a new diode - correctly this time - but did not resolved the issue. I checked transistor Q43 - controls the relay - and it checks out okay.
    Did I fry the relay? I wouldn't think a reversed diode would not do that but..... If so, can the relay be found or repaired?
    Thank you in advance for your expert advice.
    #2 5 years ago
    I rechecked Q43 and it indeed is bad. The original blackout driver board used TIP120 transistors. The Rottendog board uses a 13N10L. Can I use the TIP120 - I have several of these on hand.
    Thanks,
    #3 5 years ago
    Quoted from StratDoc:
    Thanks,
    Nope, the 13N10L is a mosfet and has to be replaced with the same. A tip120 wouldn't last a second when the blackout occurred
    #4 5 years ago
    Roger that. Ordered a few from Mouser.
    Thanks,
    This page was printed from https://pinside.com/pinball/forum/topic/blackout-gi-relay and we tried optimising it for printing. Some page elements may have been deliberately hidden.
