(Topic ID: 316684)
BLACKOUT GI out in backbox
By Jimmyhonda
68 days ago
  • 10 posts
  • 5 Pinsiders participating
  • Latest reply 56 days ago by Xenon75
#1 68 days ago
Hello,
Does anyone know what connector runs the backbox GI for Blackout? The GI is out and I’m guessing it’s a connector. I checked all fuses and they are good. Any other suggestions on what it could be? Thank you.
#2 68 days ago
There is a relay that flashes the GI for when you achieve Blackout - it could be the relay is partially bad or the wiring was modified there. The GI in general runs off the connector on the Power supply board.
#3 68 days ago
so you are saying the backbox is a blackout?
#4 67 days ago
Quoted from Jimmyhonda:
Hello,
No GI fuse good:
locate the 2 wire connector at the GI relay check that it is plugged in.
#5 61 days ago
Hello, everything is plugged in and all fuses are good. Still no GI in the backbox. Any suggestions?
#6 61 days ago
Have you checked the globes themselves?
#7 61 days ago
Remove this connector, power up check for GI
#8 57 days ago
Quoted from PINTEC:
I unplugged this connector and still no GI in backbox? Any suggestions? Thanks again for any help.
#9 56 days ago
Hello, any suggestions where to go from here? Thank you!
#10 56 days ago
Sure, get out your meter and divide the circuit up into sections. See where the power drops out for the GI. You could also use jumper wires to bypass the relay to make sure that isn't the cause of the GI not coming on.
$ 11.00
$ 27.95
$ 129.00
Cabinet Parts
Bob's Pinball Stuff
$ 49.99
Pinball Shark
$ 59.99
Pinball Shark
$ 14.00
$ 36.95
Tools
Pincoder Store
