(Topic ID: 135146)
Blackout 1495 1 message?
By Hazoff
7 years ago
  • 21 posts
  • 12 Pinsiders participating
  • Latest reply 1 year ago by Billc479
#1 7 years ago
Hi, I moved my Blackout downstairs and like an idiot I plugged in the wrong connectors even though they are colored. Noticed it right away but still must have damaged something, smelled a little funky in the backbox, anyway now it fires up but only the GI comes on and there is a message in the player 1 display that reads 1495 1. Batteries are good and I played it last night she has worked perfect since I bought it, stupid mistake I know but please does anyone know what this message means, can't find it in the manual or anywhere else? Fuses look ok, but I have no idea. Let me know. Thanks
#2 7 years ago
Have you inspected the boards for damaged components or scorch marks?
#3 7 years ago
Check each fuse and potentially replace just to be sure. I have had bad odors from fuses about to blow, usually they glow if the lights are turned off. So while they still tested fine, they were getting hot and causing smell. Also, while visual inspection sometimes is revealing, test each fuse with a DMM.
#4 7 years ago
I will try this now. Thanks
#5 7 years ago
If I recall correctly 1495 is simply a numeric designation that the game is blackout. It's not an error code or anything like that.
#6 7 years ago
If you had the black and white connectors reversed, you did some damage.
It sent 28 volts down the 5 volt rail on all the boards.
That'll wipe out chips on the CPU, driver and sound boards.
#7 7 years ago
Thats what I did. Its fixable though isn't it?
#8 7 years ago
Everything is fixable. I might have some blackout roms laying around if you need them. Blackout is a great game. It was my first pin and I regret selling it.
#9 7 years ago
I thought those numbers just meant that the batteries died and the game lost its memory.
#10 7 years ago
the numbers mean its in audit mode. either the 5101 memory or the battery is gone. settings are lost.
you can flick the power switch on and off with the coin door open and you might get it to boot.
searching "firepower audit mode" will find plenty of threads about it.
#11 7 years ago
Quoted from OHMI_Arcade:
Thank you very much, highly appreciate the offer and I will let you know, my tech is going to have look next week and he said most likely he will have take all the boards to work on. I have to say as a man who has gone through a lot of pinball machines Blackout is amazing, no multiball, no ramps and couldn't care less, something highly addictive going on with this pin. I did a lot of lighting upgrades and she looks great, high pitch and she plays fast, SFX very cool and being a lover of spinners I can't get enough not to mention the creepy background noise. Blackout mode is great.
#12 7 years ago
Quoted from Hazoff:
I say the exact same thing about my Quicksilver. Nobody gets it but me. I'm glad you have a game that's all dialed in and you can play over and over, and when the game ends you just stand there looking at it in complete amazement.
#13 7 years ago
Quicksilver is amazing, I'm trying to find the classic Stern's right now, Quicksilver, Seawitch, Catacomb etc. coolest SFX in pinball.
5 years later
#14 1 year ago
Playing a Lazurus and raising the dead here.
My blackout did something, worked one day not the next.
Had ROM chip returned but still no go.
Master display has 04 00 showing.
#15 1 year ago
open the coin door with the power off. turn the game on, then off, then quickly back on. Should come up in attract mode now. If it does, then your batteries are dead or the 5101 is bad/bad socket.
#16 1 year ago
Did on/off suggestion and now have code 600000 in player 1 display.
#17 1 year ago
Just replaced the batteries
#18 1 year ago
600000 sounds like a hi score to beat. Did you try going into settings while in this state?
#19 1 year ago
Great news.. progress. The game plays but here's the hit, when I first turn on it gives the 1495 1 screen. A quick on and off add credits and it plays fine.
#20 1 year ago
Quoted from FlipperFanatic:
Batteries weak or dead ?
#21 1 year ago
You mentioned you already changed the batteries. With the machine off, read the voltage at TP7. It should be about 3.9VDC. I've changed batteries before only to find that the battery holder failed. Sounds like this could be your issue.
$ 129.00
Cabinet Parts
Bob's Pinball Stuff
Tools
Pincoder Store
$ 14.00
$ 27.95
$ 36.95
$ 59.99
Pinball Shark
$ 11.00
$ 49.99
Pinball Shark
