Actually, looking at the first pic you attached which shows the membrane wires running down to a board, it looks like the two wires run off that other connector on the board. I didn't realize the membrane required a board, so first check that board to make sure that's not where the fault is. If the board checks out fine, check out the two wires coming from that other connector and see if they're getting power (it should be the two color coded wires I previously mentioned). If you don't have a multimeter, then in switch test mode, I'd take a jumper cable and touch those two leads together and see if you get a reading for the fire button. If not, I'd check those two leads coming off the power board. If still no reading, you've got an issue on the board. If you do getting reading coming only off the power board but and not the membrane board, then you've got a cut in a wire somewhere
