(Topic ID: 317936)
Black Pyramid swining motor causes switch issues
By robm
1 year ago
  • 4 posts
  • 3 Pinsiders participating
  • Latest reply 1 year ago by barakandl
#1 1 year ago
I am trying to repair a Black Pyramid, and it is showing some unsual and seemingly random behaviour.
Whenever any of the inline drop targets are down, it will either: tilt, jump to next ball, reset or add players. Sometimes this occurs immediately after a drop is dropped, other times its when other switches are hit after they are dropped (normally pops or hole up top). There does not appear to be any consistencty in how long one of the problems occure (ie: immediately or 10-20 seconds after a drop is dropped), nor what problem occurs (can be any of the above listed).
The game still does it with the plug to the coin door removed, so not a short in the coin door area. The problem occured with the original MPU, plus i put a brand new Weebly MPU and it showed the same behaviour - so its a switch or wiring issue, not MPU.
I have narrowed it down to this only occurs when the plug to the swinging motor board is plugged in. At first i thought it must be the switch (the swinging motor board has the moving target switch wires, plus the wires for the motor - so 4 wires - it also has a diode and cap for the switch). I tested the diode in circuit, and it tests fine - i also snipped one leg of the cap - made no difference. So then i left the plug in, but unsoldered the wires going to the board for the switch....the problem remained!!!
So then i removed the 2 black wires that drive the motor - and the problem went away. I could have 3 games, drop all the inline drops and it played perfectly! So then i reconnected the switch wires (but not the motor wires), and it continues to play fine.
So - from this - it seems that whenever the motor wires are connected (regardless if the switch ius connected or not), it plays havoc with the switch matrix somehow and causes random resets (maybe slam tilt), normal tilt, or add players or end the ball.
So the easy solution is to leave the motor disconnected, but the swinging target is a cool feature, plus its annoying me why its happening. Has anyone got any ideas what i can test or repair to try and get this working properly?
#2 1 year ago
Pic of board
#3 1 year ago
check your solenoid expander board and connector
#4 1 year ago
Every time the motor stops it spikes the switch matrix. The motor should only turn off at the end of ball, my black pyramid pops the bumpers or slings almost every time the motor turns off when the bonus countdown starts.
Make sure the solenoid expander relay is not fluttering. It may flutter if the load lamp is burned out, not working, or a LED lamp. Check the load lamp works in lamp test and you don't hear the relay flutter during lamp test
Put a cap across the motor leads and a cap from each motor wire to ground. That will help eat the noise. Not sure how big of a cap you need.... I think Stern uses 100nF caps on their DC motors in new games.
Route the motor wiring away from switches. It might be someone impossible to do this. Just pulling out the flipper wires away from the switch matrix wire in the loom helps with the phantom pop bumpers with flippers, probably would help avoid the noise from the motor getting into the switch wiring.
$ 18.00
$ 15.45
KAHR.US Circuits
$ 149.95
Allteksystems
$ 44.99
Pinball Shark
$ 22.95
$ 18.95
1,695
Riverside, CA
This page was printed from https://pinside.com/pinball/forum/topic/black-pyramid-swining-motor-causes-switch-issues and we tried optimising it for printing. Some page elements may have been deliberately hidden.
