(Topic ID: 246418)
Black Knight / system 7 flipper issues
By HeavyMetalBalls
6 months ago
  • 11 posts
  • 3 Pinsiders participating
  • Latest reply 6 months ago by slochar
There have been 6 images uploaded to this topic. (View topic image gallery).
#1 6 months ago
Here are 4 videos showing the problems I'm having. Sorry they are little scattered. I was posting them in response to some guys on a Facebook group... u gotta watch them all to get the full idea, they are short, I promise.... Thanks
Video #1
Video #2
Video#3
Video #4
#2 6 months ago
Are the EOS switches wired and set properly? If you have voltage, but they are under powered, maybe they are in hold position (open)? BK's are normally closed.
Remember the flippers are serial, so what happens to one flipper on a side will affect the other.
If that's not it...
In vid 4, is the voltage test to the flipper coil? If so, sounds like you have a return/grounding issue since the voltage is good at the coil. Check for ground continuity on your harness? this is why i thought of the EOS switches.
Is your cab grounding connected to the backbox? There should be a wing nut to hold the strap to the bb at the base. This shouldn't be a factor, but check it anyway.
There are two critical connectors for the playfield, the main one, then another to the upper pf. Check those for ground continuity.
Have you replaced or cleaned the flipper switches to make sure you have good contact? Same with the eos
Manual and schematics are here:
https://www.ipdb.org/machine.cgi?id=310
More info here:
http://www.pinwiki.com/wiki/index.php?title=Williams_System_3_-_7
Look here for info on the EOS switches if you need -
https://pinside.com/pinball/forum/topic/vids-guide-to-upgradingrebuilding-flippers
#3 6 months ago
Put new assemblies on both lowers (the ones giving me problems). The upper flippers could possibly be weak but I don't notice it cause the short shots on the upper playfield.
In vid 4 I have the red lead on my DMM to the coil. If I put the black probe to the ground strap in the backbox it shows 34 volts on the coil. If I put the black probe on the ground strap in the cab I only get about 0.6 to the coil
#4 6 months ago
I'm noticing a few things with the ground.
These pics are voltage to the coils. Black lead in different spots.
Pic #1 - 34 volts
Pic #2 - 0.7 volts
Pic #3 - 31 volts
Pic #4 - Last pic is backbox ground with red/white wire that's on the magna-save switch shown in pic 3
IMG_20190702_164238971 (resized).jpgIMG_20190702_164304964 (resized).jpgIMG_20190702_164505195 (resized).jpg15621044340182857523212621181820 (resized).jpg
#5 6 months ago
If you just installed those, I would double check to make sure you have wired it properly and that he solder is good.
Read through that Vid's guide to get familiar with the wiring. Power to the banded side of diode, ground on opposite tab. EOS goes between the middle and the ground.
Your coils do not ground to the cab normally, so your reading is interesting but not the issue. They should ground to a brown? or brown and black? wire that go back to the power board. That's where you need to check the continuity
#6 6 months ago
Ok, before I do that I wanna get ur opinion on this. I just noticed this ground strap looks like it's been cut... It was impossible to see, I had to use my phone to get a view. I also double checked the solders to the lugs. I even went over them this morning to be sure.
#7 6 months ago
Doing a continuity test with one end on the ground lug of the flipper coil and the other end on the one in the pic gives me 0.483 resistance... I really appreciate u taking time out of ur day to help me. Very cool of u
#8 6 months ago
Moved the probe from the flipper to the backbox ground and got continuity (3J3 pin 3 to backbox ground)
#9 6 months ago
Connected the ground strap that's shown in the last video to the one in the backbox. I now have 36 volts to my flipper coils. Played a game and the lower flippers are still too weak to make it up any of the 3 ramps.
#10 6 months ago
Looks like I had the wrong coils installed. I was using 50 volt coils. The website I bought them from said for "Williams machines" I guess it meant later Williams. Luckily I had a couple of the correct coils in my stash and now the game is playing great! Thanks
#11 6 months ago
Out of curiosity's sake what number were printed on the wrong coils?
$ 279.95
Pin Stadium Pinball LEDs
$ 5,899.00
Operation Pinball
$ 7,599.00
Lakewood, CA
