Hi, first time posting
We have Black Knight pinball machine and lately it's been ....quirky.... The best way I can explain it is the following:
Play the game for 15ish mins, everything seems to work fine, then it will just freeze. Turn off, then back on and the displays will strobe, the machine will make a clicking noise (not sure if it's a relay or multiple solenoids), if you don't turn the machine off for about 5-10 sec the solenoid fuse will blow, and the CPU will be in locked state. To fix the machine, replace the solenoid fuse, unlock CPU and everything seems to be fine for about another 10-15mins.
Not sure what's going on, not sure if I'm testing voltages right, but I have the following (Tested from grounding braid):
CPU: 4.92v, 9-10 White Pair: 95.7v, 15-16 Gray Pair: 11.6v, 11-12 Blue Pair: 14.75v, 13-14 Red Pair: 29.98v, 17-19 Yellow Pair: 5.45v.
Was unable to locate 12v today, but will try again in a couple days
Have some parts on the way to add fuses to the rectifiers and replace the caps on the power board.
Thanks!!!
