Checking with you all before I begin digging into things. Seems like I had read somewhere that this was normal for this machine. Before I get very far in it I figured I would double check.
I've got a Black Knight with resistors on the strobe lamp circuit (R149 thru R156) that run hot. The outer coating is flaking off and there are times I can smell them while the game is on. The driver board is discolored in that from the heat as well.
These are found on the driver board schematic page.
Should these be running so hot? If not, where's a good place to start looking? At the voltages?
