(Topic ID: 102911)
Black Knight Sound then no sound
By 04barb
  • 13 posts
  • 4 Pinsiders participating
  • Latest reply 4 years ago by ChrisHibler
#1 4 years ago
I had great sound for games and games, then no sound. I cleaned the PIA chip and rom chip on the board. I reinstalled and I got sound for a minute then absolutely no sound. If I turn off the game then back on I get no sound. Is it the rom or PIA chip/ socket? The PIA is one of the crappy AMI brands.
#2 4 years ago
It could be many things.
Start with the 9 pin connector that carries the should signals to the board. Fractured solder joints are almost always an issue.
Chris Hibler - CARGPB #31
http://www.Team-EM.com
#3 4 years ago
I replaced all the caps on the sound board and re soldered the header pins. I grounded the inputs coming from the cpu connector to the sound board and got no sounds. So it must be an issue with the sound board.
#4 4 years ago
Quoted from ChrisHibler:
Chris, which 9 pin connector? On the left or the right on the sound board? I have a similar issue with my Tri Zone.
#5 4 years ago
The sound board diagnostic switch does nothing also?
#6 4 years ago
Quoted from Toyguy:
04Barb - I don't mean to HiJack your thread but maybe I could add to it as we might have a similar issue.
When I press the test button I usually do get a sound. But again, it usually fades out or sometimes it will just continue forever.
In addition, when I do get intermittent sound during gameplay... It is usually the musical notes. No matter which setting I have selected.. it's always notes. My test button will play an actual sound.
My caps and chips are new. I too have reseated them but continue to have the same problem.
#7 4 years ago
Just repinned the entire sound board. Same issues.
#8 4 years ago
On my game, pressing the switch on the sound board does nothing. Dayday: did you have an AMI 40 pin CPU chip on the sound board? I still think that chip is faulty and I'm going to order one. Even though the socket for the 40 pin cpu chip isn't scanbe I don't trust it because on the CPU board I had to replace a 24 pin socket that was faulty because when I twisted it it locked up the game. That chip socket on the cpu board wasn't scanbe.
#9 4 years ago
Quoted from DayDay:
The one on the left carries the sound selects. Sorry that I'd forgotten about the 9 pin connector on the right, which carries Power.
#10 4 years ago
Quoted from 04barb:
If you have a logic probe, you can easily see if the processor is executing instructions.
#12 4 years ago
On a hunch I replaced the 40 pin 6808 CPU. Sound works and doesn't cut out. The old CPU was a AMI brand and I saw a video of an AMI CPU chip working then not working. Also I had an AMI chip on my bally Sapce invaders MPU board that was bad. They don't hold up well.
#13 4 years ago
Quoted from 04barb:
The failure rate of AMI chips seems much higher to me too.
I always suspect them when I encounter an odd problem.
2,100
Mt Rainier, MD
$ 75.95
Lemoore, CA
$ 50.00
