Flipper issue is solved, Now have Row 2 Switch Row issue to solve.
My Black Knight was having issues with the lower flippers not being very strong. The linkage was badly worn. So I got a rebuild kit, replace the link, the bushing, the coil sleeve, the spring and the EOS switch, as well as put in the rubber stopper.
With the rubber stopper in place it does not give the flipper very much throw at all. with out the rubber stopper seems to give it normal throw.
But regardless of the stopper being in out not, the flipper wants to shutter when in hold and the coil buzzes. When the flipper does hold, when the ball hits it, it throws it back up. Is this a coil stop issue? Mean I need to replace the entire flipper mechanism, because the coil stop is built in?
The upper flippers have no issue and I made sure to check and clean the cabinet switches after the problem the first time and I also made sure the EOS switches are gaped correctly. (I have rebuilt bally and stern flippers so I am familiar with the process.)
