(Topic ID: 279865)
Black Knight Power up issue
By Pinball41
1 year ago
  • 8 posts
  • 4 Pinsiders participating
  • Latest reply 1 year ago by Pinball41
    #1 1 year ago
    Hi, I have a Black Knight that every time you turn it on it ejects a ball into the shooter lane. After that it plays all fine. It's like it is getting a phantom signal to fire the trough once upon power up. Any idea what could be causing this to happen? Thanks.
    #2 1 year ago
    Is it instantly when the power switch is turned on, or is there any delay?
    #3 1 year ago
    only put one ball in and see if it still does it. it may think there is in extra ball because of a stuck switch. it keeps balls up top and in ball trough. You could also remove all balls and see if there is a stuck switch in switch test mode.
    #4 1 year ago
    It put one out instantly upon power up. The game play fine after that.
    #5 1 year ago
    Almost sounds like a problem with the blanking circuit, allowing the coils to fire upon power-up. Usually that will blow the solenoid fuse on the power supply board, though. Next time you're in the backbox, I'd verify you have a 2.5a slow blow fuse installed for the coils at F2. It could be masking a problem if it's over-fused.
    #6 1 year ago
    The fuse is correct. It doesn't try to fire all the coils only the trough one.
    #7 1 year ago
    Does the game have original/williams boards or aftermarket?
    #8 1 year ago
    These are original and this problem only just surfaced. It was always fine in the past.
