(Topic ID: 200206)
Black knight power supply cap
By Pinfected
  • 7 posts
  • 3 Pinsiders participating
  • Latest reply 4 years ago by G-P-E
#1 4 years ago
I am getting ready to replace the large capacitor in my black knight’s power supply. I have a brand new 35v 27000 mfd capacitor available. Can I safely use it or is it rated too high. The current one is 20V 18000 mfd. I do not want to stress any of the other components on the board so if I need to order a new cap I will. Thanks in advance for any help. Mike
#2 4 years ago
Going higher on the voltage rating is not an issue, whatsoever.
Going that much higher on the capacitance is not a good idea for most circuits but since in this circuit, it is simply a filter capacitor, you should be just fine.
#3 4 years ago
Thank you Schwaggs. Hopefully this will solve the game crashes I’m experiencing. Cap looks pretty old. I’ve already replaced the inter board connector. If this doesn’t solve the problem I’Lloyd’s have to look at game rom sockets next.
#4 4 years ago
Good luck! Don't forget to look for cold solder joints on all the header pins. Reflow the solder on all header pins and replace any header pins that look like they overheated.
#5 4 years ago
100% working after replacing the cap. Good reminder about the cold solder joints. I have found a surprising number of issued by were solved by reflowing the solder joints on header pins: from display, sound, switch matrix and power issues. Thanks again for your help. The Black Knight rides again!
#6 4 years ago
Quoted from Pinfected:
Very cool! Congrats on the fix!
#7 4 years ago
The problem with going to a huge capacitor value (18000 is huge, 27000 is huge-er) -- they result in enormous but brief current spikes through the bridge rectifier diodes at a rate of 60/sec. Make sure you have beefy diodes/bridge rectifiers in there when using these large caps.
$ 45.95
$ 129.00
Cabinet Parts
Bob's Pinball Stuff
$ 44.99
Pinball Shark
$ 89.95
$ 17.00
$ 125.00
Sparky Pinball
Tools
Pincoder Store
$ 959.00
$ 599.95
Pin Stadium Pinball Mods
