Hi,
New member. Did a bunch of searching and got some things resolved. Down to a no sound condition left to sort out.
Black Knight - all lamps, solenoids, and switches appear to be working.
The Sound Board test points show correct voltage (+14v, -14v, and 5v). I get a hum from the speaker, and when I turn the speaker pot up I get a really loud hum. I get no sound during gameplay, or in diagnostic mode.
One guide mentioned that pin 1 on 10J1 should have 18v AC. I get 11v on all the pins from this connector (to ground). I still have 11v after the two fuses on the sound board. This leads me to think I may have a transformer problem, but I am asking for advice before I start messing with it.
Also, I have owned this game since 1993. It was working well for several years. I had a no sound problem in 2000, and bought a replacement sound board (looks like an original System 7 board). This took care of the problem. I moved, and the game started to get a bit flaky after I moved it (in 2003), but still worked most of the time. I have done nothing else to this game other than clean/adjust the blade switches and clean and wax the playfield (which is in bad shape, btw) over this time. It has started to do things like lose track of how many balls are in play (switches not being made) which I can usually get cleared up. The no sound popped up again about a year ago and I am finally now taking the time to look into it.
Thanks for any suggestions you may have.
DJ Roberts
