Hello Everyone,
Ive just pulled my BK out of storage and its having some strange issues. when powered on it comes up in test and i have no mpu controlled lighting and will not go into play mode i can run all the tests but get the following strange issues.
Display test works correctly.
on the sol test everything looks to be working but when it gets to test 11 every GI light flashes and then it continues the remaining tests is that normal ?
the sound test works correctly.
the lamp test does nothing.
the mpu board led display is blank and if i press the diagnostic test switch it displays 0 briefly.
Anyone have any pointers where i should look or for what the possible issue can be ?
Everything was working when it was put in storage. although it did get moves around a few times.
Bruce
