I’m having a rough night. Thanks to this forum I had my BK playable. I was swapping rubber rings and had pulled out the novus #2 to clean. I went to show it to a friend and play a round, but one of the upper flippers was locked up again. I adjusted the switch and no change, so I went to ground the coil to make sure that part was still ok and I got no response. Then weak response on the other upper flipper. Then I smelled the burning.
I can’t tell where things got fried, but the two leds on the MPU board light and stay lit when I give it power. This page (http://pinball.flippers.info/system6repairpart4.asp) suggests a test rom is my next best option to debug, but suggests something can be done with a test led (though it doesn’t elaborate since test roms exist). I don’t have a rom burner. Do I have another option to isolate the problem or do I need to get one?
Edit: Ah, reread and I found the section for debugging without a test rom. Would be very interested in any advice for going down this path however.
